Quetion: How to make a 'Square' cutout
Bob S
Hi, My coffee table is nearing completion. Now, I have to fit the glass top, into my recessed table top. The glass is square (well rectangular), but the opening is not. I didn't miss by much, maybe 1/16 here or there, and an eigth overall. However i new this when i ordered the glass top, and i was awaiting delivery to correct the top. I have to opposite corners of the cutout that are square. one corner is shy of 90, one is proud.
Is there any guidelines anyone can suggest in remdying this, or shall i just have at it to my best ability???? I planned on this step, and now that it has arrived i do not want to mess it up. Getting the legs, and sides, and top all to fit together, WASN'T easy... Thanks,
Bob
Re: Quetion: How to make a 'Square' cutout
Sounds like a job for hand tools
A bullnose plane should get the job done.
If you don't own one and/or are nervous about hand tools, you could make a "form" - a picture frame whose inside dimensions are exactly the size of the glass plus a 16th to allow it to drop in, that you could use with, say, a top-bearing pattern bit in your router. Clean up the corners with a chisel.
chisel or rabbit pane
Bill Tindall
Or take the glass back and have them grind it on their belt sander.
PS
Bill Tindall
lay glass where it goes. Scribe around it with knife, marking gauge or what ever. Set chisel in scribe line groove and whack....gently.
Clarification of Question
Bob S
I plan to use chisels and gentle mallet...
I was more interested in 'Is there one corner I should start with', and work my way from there.
I think that I shall take Bill's PS response, rather than go back for a regrind on the glass, they already screwed up twice. I knew my cutout wasn't square, this was the 'nature of the beast' IMHO. But, next time, i will be more precise if possible. I was careful to error on the correct side of the lines so far.
Re: Clarification of Question
FredD
I would lay the glass in it's final position , scribe a deep line , and use a Bull nose plane , rather then a chisel to cut to the line , less chance for a oops.
FredD
And you can make that form
Bruce, a MN Galoot
by placing the glass in its final position on the tabletop. Clamp battens around the outside of the glass, or add a little for cushion. Rout out the recess as Bill suggests.
If you do this before, you can easily get a piston fit, no guess work involved. The only measurement required is to center the glass on the tabletop.
If it were I . . .
steve mackay
My glass shop (Baker) and I BOTH know I can't make a square ANYTHING. From picture frames to display cases. When they see me pull into the parking lot they KNOW I'm about to haul some kind of project into their shop.
I also know (deep in my heart) that when I start "adjusting" things its going to go south.
I've come to terms with all this and I'm OK with it.
If it were me I'd bite the bullet and haul my glass AND table down to the shop and have them make a (relatively) inexpensive piece of glass fit rather than take a chance of screwing up six months work. MUCH less heartache and regret.
Thats not to say that owning a neat-o bull nose hand plane won't make you smarter and better looking. THAT is a given !
Moses Yoder
Re: Next time, perhaps make a glass pattern
Moses Yoder
If you make a pattern for the glass that fits your opening it is very easy for the glass people to cut a piece that matches the pattern.
That's what we always did too
John in NM
Even so, I never expect glass to be closer than about 1/16", if you need it tighter than that, you have to scribe your wood to fit, then hope it never swells :D
Glass is IN !!!
Bob S
1.5 hours with chisel and we have a perfect(?) fit. The glass fits nicely and does a great job of not only hiding the wavy chiseled edge, but also adds a noticeable boost in quality of my project!! I think I will use glass again, having learned a lot about it on this job. Thanks for all the help.
I have been pondering using water based poly as my topcoat (over dye/shellac) but, may just build up the shellac... It is so nice to work with and have been looking for something to finish with a topcoat of shellac. I guess, if i don't like the end look of the shellac, i can put the Poly over that! One more question on table, see next post...
And thanks for all the great inputs, i learn an awful lot on this board and really enjoy it.
Have a Happy New Year to all!
Bob
Re: Glass is IN !!!
FredD
Nothing wrong awith using Shellac Bob , though not as tough as plastic finishes , it looks great and is a snap to repair.
FredD
Re: Glass is IN !!!
Larry in NW OHIO
Bob how about some pics, would love to see this project, if it does really exsist ;) ;) ;) ;) Larry
a timely post
jared
I am working on a coffee table right now and will soon get to the top. I have the glass already and will see how it goes fitting it to the wooden top frame. The glass will protect a 3d reverse contour map of the bottem of Lake Superior. We have another home on the north shore there and there is a guy up there that makes a living and quite a good one by the looks of things, making contour maps of lake bottems. Jared
Why a "reverse" contour map?
AZ in Colorado Springs
