Why Didn't I Make This Years Ago!!!!
Ken Bellock (Houston, TX)
Life is so much easier now! I am working on a toy box/blanket chest for my daughter, and the sides are wider than the capacity of my sliding miter saw, so I made this. I wish I had made this baby years ago! Assembled from just a couple of scraps laying around.
I had just finished ripping the walnut panels for the sides to size, and was trying to figure out how to cut the 15.25" wide panels square before starting on the dovetails. Laying on the floor was an exactly perfect sized cutoff to fit my miter slots for the table saw, so I laid a couple of pennies down in the miter slot, laid the walnut runners down in the slots on the pennies so they would be a hair proud of the table, put some double sided turning tape on the runners, and laid a scrap piece of baltic birch down on the table. Flipped it over, predrilled and countersank holes, and popped in a couple screws. Grabbed the block plane and put a slight chamfer on all the edges and corners. Flipped it back over. Took a really dry scrap of 2x4 that had been in my wood rack a couple of years and ran a face and side through the jointer, then cut it to fit the front and back of the sled. Glued/screwed the 2x4 for the far side of the sled first, just making sure it would cross the cut path. Fired up the saw, and ran it through just shy an inch or two from cutting through the front side. Then I grabbed the starret square, which fit perfectly into the kerf, and glued and clamped the front 2x4 to the sled. This morning I took off the clamps, fliped it over, predrilled and countersank holes for screws, zipped them in, and waxed the runners and bottom.
My first cut was exactly square according to my starret square.
