making a trivet?
making a trivet?
making a trivet?
DizD
I have been asked to take two ceramic tiles and make a hotplate trivet. My initial thought is to route a recess in a block of wood for each, leaving the tops of the tiles slightly proud of the wood, then maybe set tiles in silicone or tub caulk or something similar. Has anyone done something like this successfully? Any pitfalls to be aware of? Would a frame structure be better than a solid piece of wood?
Diz
A big beliver in the old addage "learn from mistakes of others cause you won't live long enough to make them all yourself."
Re: making a trivet?
I would make a frame rather than use a solid piece of wood. BTDT, it shrank and cracked. I made the replacements as frames and left the tiles loose so they could be pulled out and the rabbet cleaned if necessary. Depending on if the caulk will match nicely, they might be a better idea, but mine were dark tiles with walnut frames and white caulk would not have been good.
Example of ones I have made
Bill Tindall
I have made lots of them. great gifts when you can find neat tiles to put in them. We got some awesome bird tiles in New Zealand that made cherished gifts.
I Select a square of wood about 3/4" bigger than the tiles. Slice 1/8" off the long grain ends. Dado out a trough to accommodate the tiles with dado blade. Glue the 1/8" ends back on. The joint will be nearly invisible. Apply finish. Set tiles with silicon sealant. Grout. Gift. The one in the picture is 20 years old, or more, and used daily.
Or, for single ties you can make a mitered "picture frame" with a rabbit to accommodate the tiles. The "sand grout" available in a tube at Lowes works well to fill the gap.
Wood magazine had a design a few
Ray - Middletown, IN
years ago that has worked very well. It is a frame with mitered corners and a piece of tempered hardboard held in slots like the panel of a door. The tile is set on that with silicone which allows the wood to do its thing. I did add flexible, clear silicone around the edges to seal between the wood and tile. I've made a couple dozen and never had a problem or complaint.
Ray
Wood magazine had a design--I made some
Joanne in Point Pleasant
It seems to me I made a few of those trivets. The plan called for using 2 woods--a glue-up was involved to make little feet out of a different wood. I had some Bubinga scraps on hand. I did not add glue or silicon to the tile. I thought it would be a nice feature to leave it loose so it could be taken out for cleaning. I think these are 6" tiles.
That's the one, for some reason I
can't find many of the 6" tiles anymore around here. I do have several sheets of old blackboard slate and may cut some of it up for more trivets.
Ray
Thanks folks
DizD
Lots of ideas to work from. I hadn't considered grout but it looks easy and practical.
Re: 6" tiles
I see no reason why you couldn't make it with a different size tile. A 5" or 8" would work. You'd just have to adjust the lengths of the frame.
benefit of grout
Bill Tindall
Use a durable finish and the whole trivet can be gently washed. With grout there is no crack between tile and wood for stuff to drizzle into.
Small world
Mike Farinella
Joanne, I've made literally dozens of those trivets (and still do) that look exactly like that. If I remember, They are from a Wood magazine about ~10 years ago? Also, I sealed the gaps around the tile with silicone.
Regards.
I've made 8" ones but folks think
they are a tad to big. Of Course they think the 4" ones are to small. The box stores used to carry all kinds of 6" tiles but for some reason they have stopped. I need to check some of the floor stores for broken box stuff.
Ray
