Logging in 1890 *LINK*
Grant in Iowa
I have been staring at this photo for quite a while.
Here's what I am sure of:
56 logs, something like 14 feet long, some as large as 36" in diameter. Two horses, sled runners. Iced road. Has to be something like 80,000 lbs of logs. One of the captions says 36,000 board feet of lumber. This load was claimed to be the largest load of logs shifted by a team...moved about 1/4 mile on an ice road.
An interesting window into a different time. Many other great vintage photos from an age gone by at Shorpy.
FWIW,
Grant in Iowa
1890 logging photo
Re: Logging in 1890 *LINK*
Wow
And the horses, who did the heavy pulling, probably just got an apple apiece, if that.
I sure would not have wanted to be in front of that load if it had started to slide down an unexpected downhill.
Not to mention...
Randy Johnson
...how much fun they had doing that with a two man crosscut saw.
The guy with suspenders looks like he has a little bit of a paunch. He must be the foreman.
Re: Logging in 1890
Ralph Ambrosio
Grant...uh, tell them to hold up a minute or two until we can get this jam we got cleared up. This is North River, Glens Falls, NY, end of the line for a great deal of Adirondack logs. Those old timers were some tough souls.
Something wrong
Bill Tindall
36,000 bd ft of lumber green would be something north of 200,000 pounds of green logs, pine I presume.
Most likely standard 16' lengths. My estimate agrees with yours, 2 to 3 tandem loads of logs, about 15,000 bdft or at least 80,000-100,000 pounds of logs. Pine is wicked heavy green so I am guessing more than 5000 pounds/M lumber and add 25% to that for log weight.
In any case, an eye popping load. Must have had some sort of crane arrangement to load it and a very level haul road. No way to stop it down hill.
Read some more...
Grant in Iowa
My link has several replies, one of the first is from a museum on logging. They pretty much lay it out as the real deal.
Apparently,from what I have read, they graded special roads during the summer months just to move the sleds out to a railhead. I think they made them darn near level or maybe "slightly " downhill.
Once the ground froze, they hauled water to create an ice road to make efficient hauling of similar loads possible.
The logs are loaded with the same team of horses. See the information in my original link below the photo... there are more photos of loading the logs.
Regards,
Grant in Iowa
Re: Logging in 1890
Don Orr
That is definitley impressive ! I wonder if they could have moved if it was hardwood. Those horses sure look like mules to me but I'm no expert. Mules are incredibly tough-and smart.
Ralph-that area is not far from me. There is a very long history of logging in the Adirondacks. PBS had some great video/film footage of some of it. Huge log "trains" being pulled by animals through the woods on iced roads. Guys breaking up jams. Maybe Google will help locate it.
Thanks for both pics and the link.
note....
Bill Tindall
Every layer, or two, of logs has a chain around it. Apparently they loaded a layer, or two, added a chain to hold it in place then added another layer or two. Still, there must have been some crane like device to get a load that high. Sure as hell didn't roll them up there on a skidway with cant hooks!
The more I studied the pile the more I came to the conclusion they had about two modern day tandem loads or less of logs on the sled. There must have been some means of starting the sled as it would be froze to the ground at the start. Once moving it would have a layer of water under the runners like ice skates and apparently slide readily. One wonders how the load was unloaded.
green log weight
Bill Tindall
What a green log weighs depends highly on the moisture content of the log. Pine is one of the heaviest logs when green because it contains lots of water which is more dense then wood. So, these logs, which appear to be pine, would be very heavy.
Jim in Burlington Ont.
Re: Something wrong
Jim in River Oaks, Ont.
I have been doing some math on the side, the energy required to move this load can not be achieved even in perfect conditions by two horses... I am still checking my numbers, but looking at simple physics, it's not real.
Take care,
Jim
Re: Logging in 1890
FredD
The Fox series of books details logging in the South in the late 19th and early 2oth Century using Teams that started the logs downhill and with a quick release the Teamster hopefully got the Horses free of the Log train before it ran over the Team..
Many Horses were maimed and killed out right from this practice and not a few Teamsters met the same fate.
Once the logs got started down the road laid out for them , they ran onto a Sluice at the far end which got the logs back under control and into the Mill Pond.
I hated that story and the Pictures that accompany it.
FredD
With A Bit More Horsepower . .
You might move this
Re: Logging in 1890
Lynn Baker in Glacier WA
Here in the Pacific NW we see quite a few logging pictures from the 1800's. After looking at many of them, I don't think I have ever seen any of the people pictured with a smile on their faces. Logging was and is a tough, dangerous business.
Lynn
Re: Logging in 1890
Ralph Ambrosio
That's right, PBS did a great job...you ever go up to Blue Mt Lake Adirondack Museum? I am from Chatham and went to Clarkson, those logging trucks were something coming down those two lanes, Rt 56, 3, 28, 30... Man!
