Performax Belt Tracking Problem
Todd Nebel
Hey Guys,
I need some help with this. My 3M (OEM) belt on my Performax 16-32 drum sander wore out and I purchased a new replacement from Woodcraft (not 3M). I can't seem to get this new belt to track straight. I've changed the rotation of the belt three times, cleaned the rubber roller, cleaned the metal bed surface, took apart cleaned and rotated the metal roller. No matter what I do and how I adjust the pivot points on the metal roller ends (according the to manual it should track towards the tighter side), it keeps tracking towards the motor end. I NEVER had this problem until the day I replaced the belt. I don't get it? Could it be the belt? But I rotated it? Arrrg! What am I doing wrong?
Thanks,
Todd
Re: Performax Belt Tracking Problem
Dave Paine
You may not be doing anything wrong. The first belt on my Performax 16-32 did the same. I lived with the tracking to one side until I was sanding some thin strips which caused the roller to touch the belt removing the abrasive on the belt.
I purchased a new belt and this one has tracked correctly. I have not tried to determine any differences between the two belt. I was just happy to realise it was not my adjustments.
I think that if a belt is not exactly the same diameter on both sides, it would never track correctly. Not sure how much of a difference would cause such problems.
Sorry that the only solution may be another expensive belt.
Larry in NW OHIO
Todd I may be wa off here, but when I did maintanence for a door and windw place and we adjused sander belts, if the belt came to the side we were tightening it was to loose and we would tighten it more untill it would go the other way. To me your manual sounds backward, unless your belt is different than what we had. I`d try it this way and see what happens. It`s not going to hurt it. Good luck and Merry Christmas. Larry
Doug Reynolds in Seattle
Todd: I have a Performax 16-32 that takes a long time to adjust tracking. I've heard it said it can take drinking a full cup of very fine coffee in time to get the belt tracking straight. I make adjustments in 1/16th to 1/8th turn increments on the adjustment bolts. I also removed the ceramic guides as I could never get the belt adjusted before the guides chewed up the drive belt. As mentioned previously, I also have belts that are supposed to be better than OEM. They cost someplace around $30 but, I cannot recall the actual price. Patience is essential.
Bill Turpin in WNC mountains
The belt always moves downhill, or to the looser end. A out of square by a few millimeters belt can cause your problem if it rotates fast enough.
I read the Owner's Manual incorrectly
Todd Nebel in Macungie PA
Thanks Bill, I'll give it another try. I went back to the owner's manual and read it over again. I don't know how to explain it other than to say I misread the instructions because it's writen in the negative adjustment scenario (to not get this do that, verses to achieve this do this) and the adjustments need to be in very very small increments.
Todd
paul woolson
You might also want to check the squareness of your metal bet that the belt rides on. I took mine off and put a straight edge from corner to corner. One way had a rocker in the center, the other way had a cup. I shimmed up one corner until I got it spot on flat and didn't have any more problems.
It sounds like your problem is related to one specific belt but it can't hurt to check.
