On the Base 10 Number System
Yonak
Is anyone, like me, not so keen on the 10-based number system we use ? I mean, don't get me wrong, it's not going anywhere, ever since our cave ancestors discovered they had ten fingers. ..But do you find base ten is a bit awkward and unwieldy compared to, say, base 8 or base 12 ?
To wit : You can divide 10 in half just fine, but what do you do with the result : 5 ? It's a prime number, for cryin' out loud ! Nothing divides evenly into it except five and one. Consider an alternative number system, eight. Divide 8 in half and you get four, easily divided in half to make 2 which, divided in half gets one, the lowest integer there is .. the building block of numbers. How about 12 ? Even though twelve can only be divided evenly twice (still once more than ten), the magic of 12 is that you can evenly derive one half, one third, one fourth and one sixth of twelve, whereas you can only evenly get one half and one fifth of ten.
..And then there's ten-based decimals (redundant by definition of the term, I suppose). Half of 10 is .5. Half of that is .25. Half of that is .125, then .0625, then .03125. Do you see where this is going ? In base 8 it's : .4, .2, .1, .04, .02, .01, etc. In base 12 it's .6, .3, .16, .09, .046, .023.
Whomever invented the 12-month calendar, the clock, the ruler and the number of eggs in a carton, all based on 12, had it together. They all divide evenly by 1/2, 1/3, 1/4, 1/6 and 1/12 of a year, an hour, a foot or of a dozen eggs. It's what allows your pest control company to give you quarterly treatments and always be there on the same day of the month (that is, if they're more punctual than my pest control company).
..And don't get me started on the number of days in a week !! Who's lame-brained idea was it for a week to have 7 days ? ..A prime number at the get-go ! If you decided to adopt a regimen of wearing your socks two days in a row you'd still have a day of wear left on the last pair when laundry day came around.
Re: On the Base 10 Number System
Re: OK, I'm in:  Base 11.09!
BrianA from Monument
Quite frankly from a computer perspective base 2, 8 and 16 are the only useful numbering systems.
Base 16 is the best with base 8 close behind.
But none of them can be implemented without the primitive nature of base 2.
Sorry, i am a former computer engineer bs, meng.
Jesper, Denmark
Jesper, Denmark
The bimary system would solve all your perceived problems, but try to use it in non-computer systems. What the heck is 100111000001110101001?
To really implement the 12 base, we would have to change genetically, and have six fingers snd six toes :(
I'd argue for base 20
except it would take too long to take my shoes and socks off to count out my change every time I went to the store.
del schisler
If you count on your finger's backward's . Like 10 9 8 7 6 and than 5 more is 11 ??? can you explain this?? thanks
I sympathize with your pain but
Gary Smyth
for example, remember, there were originally ten months in a year but about the time of the Roman Ceasars the Egyptians told him there needed to be twelve because for the sun to arrive at the same place in the sky twelve cycles of the moon took place. Therefore, a change was needed. Julius and his successor, Augustus determined that a month named after them would be just fine. So quintus (5) became July, sextus became August, septem (7) moved to the ninth month, the former eighth month, October (8) is now the tenth month, novem (9) is eleven and decem (10) is twelve. All of this more or less became official with Pope Gregory hundreds of years later in 1582. Even this met with opposition. One of the reasons given then was that the Catholic "Roman Antichrist" Pope�s real purpose was to keep true Christians from worshiping on the correct days. Even then, and perhaps more than now, science and religion came into conflict. The "new" calendar, as we know it today, was not adopted uniformly across Europe until well into the 18th century.
Re: I sympathize with your pain but
Larry in NW OHIO
OUCH I think I`m getting a headache, I believe I`m going to lie down. Larry
Jesse Cloud
Very interesting thread!
I am totally amazed at how worked up people get when something is a multiple of the number of fingers they have. Take the Milennium - what nonsense!
I used to be in computers too, but now I'm retired and try to avoid numbers. In woodworking I usually start by drawing something that has pleasing proportions. I'll cut a piece of wood and then scribe that distance onto the next piece to cut.
Most of my joinery is mortise and tenon, so I make a jig to route a mortise and mill tenon stock to fit the resulting mortise. No real need to know the exact width of the mortise.
Certainly can't avoid all the math all the time, but for me its just another opportunity to make a mistake.
What a long slide for a guy who used to do binary and hex arithmetic in his head!
charles in mtl.
The metric system makes so much sense it is surprising the amount of resistance people have for it. OK if you divide 10 by you have 5 and so on but think in terms of scaling and proportion...it is unbeatable.
Jim in Burlington Ont.
I Totally Agree
Jim in River Oaks, Ont.
I'm with you Charles..
The metric system is so straightforward, understanding is all about attitude. My daughter laughs out loud when I speak in quarts and ounces, she thinks I'm a "wizard".
Recent math scores from around the world show that the countries placed in the top 20 are all metric as well, countries in the 30+ had a few including our southern neighbour, sad results, can you see it now, look up charts on the walls of future shops for multiplication and division of fractions vs a simple 10 based system.
Take care,
Jim
It's called the devil you know!
Bill Howatt
I agree the metric system makes more sense and I'm very happy in metric temperature measurements and am getting more so in weights and volumes at the grocery store. But I still measure my weight and height in lbs, feet and inches even though the metric weight would be a nicer (lower) number! Speeds and distances in km/h and km are now routine but it I want to figure gas consumptiom for my car I convert the kms and litres consumed into a MPG rating - it makes more sense than litres/100km.
In the shop I still am stuck in feet and inches. I know what 1/4" looks like etc.
The reality is that for a clean conversion you have throw away all the non-metric tools like drill bits, tape measures, plans and just do it. Too easy to keep going back. This is likely why I'm happy with metric temperature, when the change came I refused to buy a thermometer with both scales on it.
Bill
A bunch of Baseless Assertions
Bartstar
Too much time on your hands?
mdclor
or cabin fever set in early! :D
R Payne
You don't quite have it.
Half of 10 is not .5 it is 5. Half of 1 is .5.
In base 8 half of 10 would be 4. In case you don't understand that, in base 8 the numbers would be 0 1 2 3 4 5 6 7 10 11 12 13 14 15 16 17 20 and so on.
Some think the base 12 (which we don't really use) came from the number of knuckles of one hand (4 fingers by 3 knuckles). And the numbers in a base 12 system would run 0 1 2 3 4 5 6 7 8 9 a b 10 11 12 13 14 15 16 17 18 19 1a 1b 20 and so on. (there could be another number created instead of using a and b).
I suggest instead of using decimals, use fractions. Fractions are very easy, particularly with the limited fractions used in woodworking.
ron
Frank H
The "sense" in the metric system comes, not because it is in base ten, but because everything is done in the same base.
If we adopted a similarly uniform system, but with a better-chosen base, the advantages would be even greater.
Moses Yoder
Re: 7 day week
Moses Yoder
Well, according to the Bible you might want to take up the 7 day week with God. Apparently it was His idea. Look at Genesis chapter 1. I just wish our measuring system was based on 10, like the metric system. Who ever thought the inch was a good idea? I like the number system based on 10 just the way it is, thank you very much. Half of 10 is not .5, and half of 8 is not .4. I can divide 5 by 2 just fine; it is 2.5. I did that without a calculator. And half of 2.5 is 1.25. Etc. ad infinitum.
Yonak
You're right, of course. I meant half of 1, not half of 10, as I was referring to decimals. My mistake.
Re: 7 day week
Yonak
I'm not an expert on this and I could easily be corrected, but, as I understand it : We used to have a lunar calendar. The solar calendar came later. The phases of the moon defined the weeks. Since the full cycle of the moon, roughly, is 28 days, each week is comprised of one quarter of the moon's cycle, 7 days.
Since the moon's cycle isn't exactly 28 days, however, there was an official whose job it was to announce when the new month arrived by when he determined the first crescent following the new moon could be observed. That was called calends. When the moon became half full (a quarter cycle), that was called the nones and designated the beginning of the second week. Similarly, he announced when the ides was by when the moon was full. This meant that a week wasn't always 7 days, but, more often than not, it was.
How about... *LINK*
Brad Chenoweth
a Bob's Rule? I just thought this was kind neat(and simple).
Brad
Bob's Rule
Sounds like a bar bet that got out of hand
Henry Higginbotham
"Twenty bucks says I can invent some ridiculous measurement system that solves a problem nobody had, write up an illogical treatise on the matter, and get somebody to pay a bunch of money for a short, steel rule."
"Dude, you're on!"
