Spot on pants (OT)
Spot on pants (OT)
Spot on pants (OT)
Larry in NW OHIO
I have a good pair of kakai pants that are 95% cotton and 5%spandex. I got a dry marker dot on it, does anyoe know how to get it out. It has been washed a few times, but has not been in the dryer as of yet. I tried a few of the new fangled type of spot cleaners, but no luck, so hoping someone would know of one of the old fashion ways of getting it out, I`ll still try something that would be new. Thanks to all and Merry Christmas. Larry
Re: Spot on pants (OT)
Carol Reed, Strawberry, AZ
I'd take it to the cleaners. Tell them what it is and what I had done to it at this point. Probably less than $10 and the pants are probably worth it.
John Veerkamp
Ordinary alcohol takes out most ink and marker stains and won't bother the fabric dye. Best to test in a hidden spot first though.
Also isopropyl (rubbing) alcohol...
acetone would probably work also.
Most of the dyes used for khaki coloring are pretty color fast. I would go with an alcohol before I went with acetone. Taking it to the cleaners may be your best bet.
Howard Norman
As Carol Reed has said take the pants to a dry cleaners. Any decent dry cleaner will have the chemicals to remove the ink stain. Just tell them what the stain is to make like easier for them. Both my father and brother were in the dry cleaning business for years and I acquired a lot of the knowledge many years ago-say 50 years ago to be more exact.
the challenge of removing dye, not just moving it
Bill Tindall
To remove the dye you must either bleach it, a possibility given that these dyes are not particularly sturdy compared to fabric dyes, or you must transfer it from where it is at to some place else.
Adding solvent is just going to move it around the pants. You have got to supply some place for the dye to go to. There is a bit of technique involved but if you place an absorbent material under the spot and then add solvent from the outside of the spot so that it wicks in to the center, you will be able to wash the dye from pants to absorbent. Bathroom tissue (AKA toilet paper) can be a good absorbent. If you add the solvent to the center of the spot you will reinvent chromatography, moving the dye across the pants and perhaps separating the component colors.
Stain sticks have a form of bleach that typically doesn't affect fabric dyes but may go after weeny dyes like markers. This is what I would try first.
Looks like you might have some new shop pants
Dave Bair, Eaton Rapids, MI
Steven Antonucci
You just described every pair of pants I own...
steven antonucci
The truck principle
You're not alone.
My younger son and I have, a couple of times, discussed trucks, and concur that they don't look right until there's a dent or two on them. I think I've unconsciously extended that principle to my clothing.
Strangely, my sweet, patient-to-sainthood wife does not think this is funny.
Just Wear 'Em to the Shop..........
Barry
Just wear those pants to the shop a couple of days and that little spot won't be so prominent anymore.
George Colonel's Workshop-Havertown PA
All my pants look like they came from leopards, Larry.
My dad's pants looked that way also. Both my mother and my wife were unhelpful.
My Dad used to hang his pants on a hook on the inside of the bathroom door. When he needed them, they were always there. After a few months, my mother couldn't stand them anymnore, and put them in her Easy wringer washer. Dad complained that she had "washed all the strength" out of them.
Pants should be something to feel strongly about. :b
George
Al Stokka - Cambridge, Iowa
Larry,
Sorry to hear about your misfortune. I know how frustrating that situation can be. While I have no personal experience with the product, Amodex Ink and Stain Remover, seems to be, from internet research, the go to product.
From: http COLON SLASH SLASH www DOT amodexink DOT com/stain-removal DOT html
HOW TO REMOVE SHARPIE�, EXPO� & OTHER MARKERS
To Remove Markers from Fabric:
Apply Amodex to stained area. DO NOT WET AREA.
Rub in well with a stiff brush or your fingernail.
Continue rubbing until the ink is almost gone.
Rinse or launder.
Note: The center area of marker stains will disappear first. keep rubbing until the edges are clean.
HOW TO REMOVE WHITEBOARD & SMARTBOARD "GHOSTING!":
Apply Amodex to a rag or paper towel.
Rub over the whiteboard surface.
Wipe clean with a damp cloth.
Note: Amodex will remove permanent marker that is accidentally used on a whiteboard, smartboard or other such surface. Follow directions for "Other Porous Surfaces".
Good luck I'd appreciate hearing about your sucess.
Al
My wifes' "sharpie" solution
Frank Grambo
It has happened to me.... My wife grabbed a "Sharpie" and wrote in 1 inch letters.
" Work pants only" . Right between the pocket and the zipper. Problem solved.
Re: My wifes' "sharpie" solution
Barry
Man, that's harsh! If my wife did that, I'd miss her terribly.
