Limbert table
Limbert table
Limbert table
McKay
I completed my wife's Christmas table. It is the Limbert table that was featured in the FW magazine. I made it using QSWO. Electrons were burned in processing the legs, but the top was hand planed and I used winding sticks to flatten the top out. I did not have access to a planer that would do 27 inches (does anyone?) so hand planing was the best way to go. It gave me a cardio workout, but it was well worth the effort.
I also finished doing six of these frames for my sister. They were built with alder, double splined, routed with templates for the outside, inside, and rabbet in the back for the 3/4" clock face. A william and hussey molder was used to do the shape on the flat.
All I have left to do for Christmas is 4 lamp stands, a Asian styled night stand, and two couch tables. No rest for the wicked. :D
Re: Limbert table
Re: Limbert table
Very nicely done. She'll be pleased.
Don't have a 30" planer either, but the Performax 22-44 got my 36x52 kitchen table top (below) within a "steenth" of flat and I then used a framed belt sander and a straight-edge to take out the very slight hump in the middle.
Re: Limbert table
Framed belt sander?
Joe Shelton
Would you mind telling me what that is?
Joe
Re: Limbert table
Clint Searl
Beautiful work
Clint Searl
Re: Limbert table
nice  piece of work
Bill Tindall
I'll bet finishing was a challenge with all the intersecting surfaces.
I would have thought quartered oak would have been very difficult to plane. Any problem with the flakes tearing out?
Re: Limbert table
Re: Limbert table
Jim Dillon
Very nicely done and what wonderful Christmas gifts. Look forward to seeing the rest of your holiday projects when you get them done.
Jim
Re: Limbert table
Re: Framed belt sander? *LINK*
Hi Joe,
Several brands of belt machines make a frame to carry the machine. I have a Ryobi BE-321. The frame holds the abrasive parallel to the surface to prevent digs and gouges, and is also depth-adjustable. See the link for a picture.
The frame indexes the belt to the surface and controls how must material is removed. I've easily removed just the finish from veneer ply without burning through the veneer with mine.
PC and Bosch used to make a frame for some of their lines, but I don't know if they still do.
Sander Frame
Re: Limbert table
22-44 sander
McKay
I had one once and got rid of it because of the troughs that it would put into the wood on every oscillation. For the money, the three planes that I have are much less expensive and very quick. Probably as quick as when I ran the wood through the sander a bazillion times.
Re: Limbert table
Jim in Burlington Ont.
Re: Limbert table
Jim in River Oaks, Ont.
This is absolutely beautiful!
I have been working on the same table design with some of my own additions, I really like the look you were able to get, the clear finish also looks great on the qswo. I am also working with qswo and i have my top hand planed down, it was not too hard, I enjoyed the scent of the oak in my shop.
Thanks again for sharing, a truely lovely table, you have created a beauty.
Take care,
Jim
Re: Limbert table
Re: Limbert table
Frank
That is a nice looking table, so much I just glued my table up yesterday. But my table is out of black walnut. I have a lot of black walnut in my wood pile. The wife seen it on the cover of FW and "Hey, I want that table for the living room". I do have a 22-44 sander that I sanded the top flat. It will be in the living room by Christmas.
Frank
Re: Limbert table
Re: 22-44 sander
Well, you could always get a "Timesaver" and then rent out use on a schedule of some sort. :D
The "trough" was a problem until I adjusted the outboard end of the drum a bit high rather than trying to get it deadnuts parallel. Now if I have to do a piece by overlap, it will leave just a very slight crown rather than a valley. It's then easy to bring the surface level.
My only issue with the sander is, even though I use a gum block to clean it, it still has the tendency, even with very light passes, to load the abrasive which results in a burn streak down the workpiece.
Re: Limbert table
Re: Limbert table
FredD
Hand planing ,fine work and Nice figure to the wood, what moe could she ask for?
FredD
Re: Limbert table
Re: 22-44 sander
doug f, san clemente, ca
Mark - i don't mean to hijack the thread, but I have the same problem with my 22-44, the least hint of more than a 1/32" pass and I've got burn marks. Not much fun on end grain cutting boards.
Have you found a solution; the big erasers and even washing in Simple Green don't seem to have any effect.
Thanks.
Doug
Re: Limbert table
What's Needed
Is better abrasives that don't clog.
As far as basic dimensioning, I use 36 grit with the top feed rate to get things close, then work up to 100 with light cuts. From there it's the RO, etm. I tried going to 180; a disaster with the burns. May be from the sugar in the maple and cherry I work, but . . .
