bowed plywood
bowed plywood
bowed plywood
ed hoxter
anyone have a way to straighten bowed plywood. i have a piece of sapele 3/4 x 25 x 44 that is bowed. i've had it under clamp pressure for 4 days with no luck. i'd hate to throw this away. NEED HELP! ed
Re: bowed plywood
Clint Searl
Re: bowed plywood
Clint Searl
It's a nice size for the top of a coffee table. Use it as the show face of a torsion box (to flatten the bow) and design a simple base on which to float it.
Clint
Re: bowed plywood
No help here
Usually when plywood bows, it's because of a moisture problem, like the convex face has absorbed moisture and swollen slightly. It's conceivable that misting the convex face on a regular schedule could cause it to begin to bow in the opposite direction, but that is a total guess, and you're on your own if you want to try it.
Like Clint suggests, it might be best to flatten it with a torsion box type structure under it. Just a perimeter frame isn't likely to take the bow out of the middle of the panel.
Ellis Walentine, Host
Re: bowed plywood
Re: bowed plywood
Bruce, a MN Galoot
I had some cheap-ass baltic birch from Menard's (never do that again) that bowed severely after I machined and finished it, but before I installed it. It was too late in the process to replace, so I found a way to make some relief cuts in the parts that wouldn't show. Then it flattened out under constant pressure.
Other than that, I have no ideas.
Re: bowed plywood
relief cuts
del schisler
burce said in his post. I belive that is the only way to get relief . I have done that on some wood .As a last resort or i needed that wood.
Re: bowed plywood
Re: bowed plywood
Larry in NW OHIO
Bruce Years ago when I built my shed, I bought about15 sheets of 1/2X4X8 sanded one side birtch ply. It looked good in the store. I got it home and put it up and left it a couple days and went back and looked at my great piece of work and the stupid stuff was splitting in the front right around the grain and pretty badly. Needless to say I was kind of upset. I went to my computer and the Menards web site to tell them what they could do with their Chinese slabwood. But I found a place where they had complaints filed. So I told them what happened. They sent me a letter that they sent to the manufacturer, didn`t hear anything for four weeks so I sent them another email. They sent me another email of what they sent them again, and it got kind a blunt if they didn`t do something. In a few weeks I got a check for all I paid for the ply. I got to say that was more than I expected. You might try that. Larry
Re: bowed plywood
Re: bowed plywood
Howard Acheson
What did you plan to use if for?
In the shop I was involved with we could frequently use warped plywood as long as there was some sort of framework underneath.
Re: bowed plywood
Double-thickness it
Hoa in Alameda
What do you plan to use the plywood for?
I once had a piece of plywood that bowed as yours. I doubled it, gluing back to back, and used it as the top for my son's workbench. It's been almost 8 years and the top of the workbench (now used mainly as an assembly table) is still straight.
Re: bowed plywood
doomed
Bill Tindall
The cheap Chinese stuff can come in at 18% moisture or more. It wrinkles like a potato chip when it dries. A friend made a shipping crate out of some. I wrestled some into submission in a well braced cabinet.
Re: bowed plywood
Would a torsion box be strong enough?
This is a fairly small piece of 3/4" ply here - thick for its size. A torsion box that could hold that straight would need to be fairly beefy, wouldn't it?
Re: bowed plywood
Re: doomed
ed hoxter
at $127.50 a sheet, i would'nt consider this cheap. i'mn building my wife a sewing cabinet. the bowed piece is for the back of the cabinet. delux sewing cabinet plans= rockler. i have thought about relief cuts on the back side, but not sure if it would work. ed
Re: bowed plywood
Oh!  I didn't read carefully
Bill Tindall
Thought we were dealing with Chinese birch. Of course it may be Chinese Sapale.
If you stop by the shop I will sell you two sheets of 3/4 real mahogany with thick old timey veneer that is flat.
Can you mount it in a frame that would hold it straight (ie. frame and panel)? In fact how is it to be mounted that the means of fastening it will not flatten and hold it flat?
As far as straightening, I still think you' re doomed. I have straightened solid stuff by tensioning it and then steaming but that won't work for plywood.
Re: bowed plywood
Battens?
mdclor
Any way you could glue a couple battens to the back and incorporate them into the plans?
Re: bowed plywood
Re: Oh!  I didn't read carefully
ed hoxter
bill, there's a cabinet on each side of center, the backs of them are attached to the bowed panel. i'mn afraid that it will throw everything out of alignment. ed
Re: bowed plywood
What I've done...
You didn't say whether this is sapele both sides or which way the sapele is facing in the finished piece -- bowed side in or out -- or whether it is bowed in its length or width, but if there is room inside the cabinet you can flatten it out with crowned battens, like mdchlor suggested. Like the torsion box solution, you will have to engineer the battens so that they collectively have enough beam strength to pull (or push) the bow out. That shouldn't be too hard, even though this plywood is 3/4" thick.
I've often used this device, particularly in table tops. The "engineering" is seat-o-the-pants: cut two or three straight beams, say 2 inches square, to span the bow. Space them across the convex side of the panel and clamp them at the ends to the edge of the panel and see if they pull the bow flat. If the bow is still there, you need heavier beams. If it is gone, you can plane your beams thinner until the bow starts to return, then hand-plane a slight crown on the side of the beam that contacts the bow in the plywood. Increase the crown as needed until the bow pulls flat when all the beams are clamped to the bowed piece.
This method works for any width or species of beam. In your case, if the bowed side of the plywood is supposed to face the outside of the cabinet, you can put convex beams on the inside and pull the center of the bow flat with screws or glue. You'll have to deal with the appearance inside the cabinet somehow. Too bad there aren't any vertical dividers in there that you could use. You could attach a long strip to both the divider and the back with screws.
I wouldn't recommend cutting relief kerfs in the back of the plywood unless you know what you're doing. Often this method will telegraph the kerfs to the face of the panel.
Re: bowed plywood
Louie Lovas
Re: bowed plywood
Louie Lovas
I had this problem not long ago and. I chose the relief cut alternative (saw kerf) and then wedged the kerf. I glued in a wedged-shaped spline to the counter-act the bow. Did work reasonably well.
Re: bowed plywood
Clint Searl
Depends
Clint Searl
Re: bowed plywood
FredD
I must getting slow on the uptake , but if your "bowed panel"has a hump so to speak and you are fastening it to to two cabinets which would be four ends running down the piece form top to bottom that should provide all of the fastening surface you need.
Personally I would run a top rail and one lower down that holds the two cabinets apart and fastened together regardless of a back and that also permits a thinner panel then one 3/4" thick. Plywood is not that hard to hold flat while fastening and gluing it.
Depending on the design and how far ahead you thought it out , I would more then likely have the front top rail for both cabinets a one piece continuous rail that worked as the back rails would in holding the cabinets together without the use of a back panel
FredD
