band-saw blades
band-saw blades
band-saw  blades
John Holmes
I have been experiencing problems with using 1/8" band saw blades. I cannot seem to get any life out of them. Even though I am only cutting 1 1/2" soft wood, they keep breaking. I broke two of them within an hour the other day. This happens even though I am not making terribly sharp curves. The two the other day were from Lowes. I have had the same problem with blades from Sears. Any ideas as to what I might be doing wrong? Does someone have any other companies in mind that might have a better grade of blade? Any suggestions would be appreciated.
Re: band-saw blades
Re: band-saw  blades *LINK*
del schisler
why not buy good blade's? You can buy from from here. I belibe they warrenty on breaking at the weld? How many wheele a 2 wheele or a 3 wheele? If a three wheele they make a thinner blade for those. Here is the link Also did you check for blade drift?? You may be trying to keep the wood on the fence and that is putting the blade in a bind ?
http://www.highlandwoodworking.com/bandsaw-blades-
Re: band-saw blades
Re: band-saw  blades
Larry in NW OHIO
John I don`t know what would be happening to your blades, but if it were me I would take them back and tell them what happened. They should give you a new one, if not leave and get your blades from like Highland, Suffolk Machinery, go to www.suffolfmachinery.com and there are others, I`m sure more people will post. I haven`t bought from Sears or the box stores since the internet really came into favor and I never broke a blade or had the trouble I had with the "Cheaper"blades. If you order from one of Woodcentrals advertisers, then that helps WC some how. Good luck Larry
Re: band-saw blades
Re: band-saw  blades
As others have said, there are better sources for blades. I've used Highland Hardware for years. I've also bought blades from Suffolk. Both are quality.
I do have one question though. Why do you feel you need a 1/8" blade? Are you sawing curves that tight? For most work, I can usually use a 1/4" blade. For really tight work, I use a 3/16". A beefier blade would have less tendency to break.
Re: band-saw blades
Re: band-saw  blades
Alan in Little Washington (NC)
There has to be something else going on besides the possibility of bad blades-
Too much tension?
Incorrectly set guides?
Making too tight of turns?
Blades stored incorrectly?
Re: band-saw blades
question
Bill Tindall
are they breaking at the weld or random location?
Re: band-saw blades
Re: band-saw  blades
Joseph Mulherin, Sr
John, I think you would have better luck if you used say 3/8" blades for most of your cuts and save the 1/8 and 1/4 ones for finer close turning cutting.
Also, make sure you guides and alignment blocks are in correct positions and not binding on the blades....and run the wood slowly into the blade...let the blade do its work and don't force it.
Re: band-saw blades
Re: band-saw  blades
John Holmes
Thanks to all of the people that answered my question about band-saw blades. It gave me a few things to think about and gave me some alternative sources also. Thanks guys!!!!!
Re: band-saw blades
How many teeth per inch?
Dick Coers
If you are cutting a resinous pine that is 1 1/2" thick, and using a fine tooth blade, you may be filling the gullet with sawdust and then overloading the blade to make it cut. Go to courser tooth blade and see what happens. You could also repair the blades if they are not kinked. The silver solder kits sold for making band saw blades works very well. I use a disc sander to make a scarf joint on the blade, then solder with a propane torch.
