Re: drum sander choice
Dave Paine
I have a Performax 16x32 and last year purchased a 30in wide "Flat Master" which is a much larger machine than the Sand Flea, but also has the drum mounted below the table.
Sanding a bowed panel flat will take some trail and error with either machine.
I made a sled for my Performax due to finding I was getting more material removed from the middle than the ends. I think a flat sled would help with a bowed panel on a top mounted drum machine like the Performax.
For a bottom mounted drum like the Flat Master, I would start in the middle of the board and sand to one end. Flip and so the same for the other end.
After using the Flat Master, my Performax is now just gathering dust.
A big advantage of a bottom mounted drum is lack of heat. The Flat Master uses a hook and loop attachment of the paper, and the drum is set to barely touch the wood when at rest. Turn on the machine and centrifugal forces expand the paper slightly, just enough to sand the wood. Works well. No heat, so you can sand paint, varnish etc, if needed.
With my Performax I had to frequently clean the roll to prevent burning. With the Flat Master I do not get any buildup.
