Workbench finally ready for work!
Stephen Kirk
OK, I need some dog holes and to put some finish on the top, but this big fella is together, in place, and already getting used. It was quite a bit of work. My sizes are a bit smaller than Bob Lang's plans, but I went TAP with the lumber I had (ash trees from my front yard). Trees had to come down (danger to the house), so the cost of the bench was around $200 to haul, cut and dry the lumber, than another $240 for the vise.
My trays are fairly level, but I do have to shim them a bit and things aren't perfect. I'll work on making them a bit better, but they work just fine right now. It is just a bench. I like that I can flip them over and make a flat surface. I will put holes in a few of them to hold planing stops or to work as tool holders. On the far right one, I hung my pencil sharpener. Just flip it over, sharpen, then back out of the way.
The twin screw is nice, but a bit tricky to attach. I followed Bob's plan and just glued the blocks under the bench that the screws run through. Seems plenty solid. I love the nearly 24" room between the screws, it'll hold nearly anything. It doesn't clamp super tight, though, so I think I'll add some leather to faces to increase the grip.
I'll start drilling some dog holes (do them by hand with bit/brace, heard that makes holdfasts work better). Then I just have to order some holdfasts from Joel.
I love the bench. Big, stable, feels like a rock. The ability to pop a tray out and clamp in the center is really nice. With tools in the trays, I can slide boards over top without knocking everything off.
Yeah, I decided it was time I got into one of my pics. Plus I had a few of my helpers around.
Now it's time to get back to some furniture!
Re: Workbench finally ready for work!
Matt Overton
Nice job. Enjoy it. Funny how much time and effort benches take.
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Hey, There's a guy blocking the view!! :-)
Awesome looking bench, you should be very proud, I like that you moved the twin screw to the face.... I know I love my bench, making shop furniture that works is such a great feeling!
Well Done!
Take care,
Jim
Thats REALLY nice !
steve mackay
Larry in NW OHIO
Stephen Absoluty a great looking workbench, to bad you`ll need to work on it and get it dirty and skuffed up. Also your two helpers are still inspecting it to see if they approve of it, they sure are cute. Larry
Virgil Johnson
Nice bench.
FredD
To bad you had to remove the Ash trees , but I see they are still around in your sturdy bench.
Nice touch to dovetail the rail.
FredD
handsome bench, what is its first project?
Bill Tindall
George Colonel's Workshop-Havertown PA
Good Afternoon Stephen,
You did a great job in evert respect. I especially like the situation where you could use the ash in the bench construction, and spent the time and effort milling the wood which youy can now use in a new form for a lifetime+'s worth of woodworking. I think that is the waty a project should come together. Kudos!
George
Sweet!
Jennifer@Indy.USA
Nice! Love your "helpers".
Jim Dillon
Stephen Kirk
Yeah, they sure do. Heavy work, too. I don't plan on building another one any time soon. I'll just enjoy this one.
Stephen Kirk
I may put a wagon vise in, but for the most part I don't use tail vises. Shop is kinda small, can't get around the bench anyway. Face vise is the most important for me.
Stephen Kirk
Trees were leaning towards the house and ash around here isn't too healthy, so they had to go. But, they remained useful. Rest went for heat and the small bits were chipped up and still used.
Re: handsome bench, what is its first project?
Stephen Kirk
Well, I took apart my drill press and cleaned the gears on it, if that counts. I have to make presents for the nieces. Then I have an order for some Morris style chairs.
Stephen Kirk
Many thanks too all!
