Drawer material
Drawer material
Drawer material
David Dircksen
What is a fairly good wood to use for drawer boxes? In the past I would use 1/2 inch ply. Is ther something better that looks nice but is not too expensive?
Re: Drawer material
Re: Drawer material
For utility pieces I like Baltic Birch plywood that has numerous thin plus. Not unattractive, strong, stable, consistent, good stuff has no interior voids and not lapped plays. A local supplier carries ready made drawer sides of baltic birch, but they were WAY more expensive than making your own.
Most any "white" wood is suitable for interior parts including drawer boxes. Poplar and soft maple come to mind. Certainly more traditional than plywood. If you are making classic furniture, the drawer box should be softer than the runners or sliding surface in the carcass. Easier to repair a worn drawer later (many years alter) than repairing worn internal parts.
Re: Drawer material
Re: Drawer material
Jesse Cloud
Baltic birch ply is my first choice for utility drawers. If you want to avoid ply, then poplar works well, just avoid any with green tones, or paint it.
For fine drawers, I resaw maple to 1/2 inch. I like to use a contrasting wood such as cherry or walnut for the front. Also, a fine drawer should have a real wood bottom. I make a 1/4 maple panel. Orient the panel so wood movement will be front to back. Leave the back of the box short of the bottom groove and run a small screw through a slot on the back of the bottom. That way the panel will slide front to back as it moves.
Re: Drawer material
Re: Drawer material
Poplar is a traditional drawer box wood that is in most cases low cost.
Tom
Re: Drawer material
Another vote for poplar
also soft maple.
Realistically it depends on what sort of plywood you can get for the bottom. I typically get sheets of 1/4" poplar plywood from my supplier. I've also got a fair bit of 4/4 poplar that I picked up a year ago. Therefore I make poplar drawers.
Re: Drawer material
Re: Drawer material
John McGaw
The usual answer is: whatever is lying about. I've used soft maple, hard maple and poplar most often but sometimes southern hard pine, sycamore, and oak have been nominated. I have even used lower-grade cherry for drawer parts when it seemed appropriate. Sometimes a combination is called for such as maple sides and back and center bar with aromatic cedar panels in the bottom when strength is needed in an uber-large chest drawer. Almost any stable wood will work fine and since secondary wood will be seen seldom it doesn't really matter a lot so I usually just scan the wood rack when the time comes and grab whatever seems right at the time. Unless the project is strictly utilitarian like kitchen cabinets or bathroom vanities or workshop storage I avoid any sort of sheetgoods (even for drawer bottoms) since big sheets of anything are just too much of a PITA to handle in a small shop with low ceilings.
Re: Drawer material
PS
Bill Tindall
If the drawer is mounted on hardware then ash is a nice choice. But you don't want a hard drawer side rubbing on wood runners. Worn drawers are easier to fix than worn dividers and runners.
Re: Drawer material
Jim in Burlington Ont.
Soft Maple and Cedar
Jim in River Oaks, Ont.
Depending on the look I want with an open drawer, I usually use soft maple and recently went to cedar for the drawer bottoms.
take care,
Jim
Re: Drawer material
Re: Drawer material
George Colonel's Workshop-Havertown PA
Good Afternoon David,
While I have used red oak and maple, I tend to do mo0st of my drawerts with poplar. I buy 5/4 and resaw and plane to 3/8" generally, but occasionally go to 1/2" thickness depending on the size of the drawer. I also use either box joints or dovetails, and employ plywood bottoms. My attempts at box jointing/dovetailing plywood have been unsuccessful.
George
Re: Drawer material
Re: Drawer material
FredD
Since I Dovetail drawers regardless of the use , for Kitchen Cabinets and roll-out trays which are fitted with side mount slides , I use solid Yellow Birch , milled to a 1/2" thickness.
For Furniture where I deem the drawer is part of the look , I use quarter sawn Sycamore, a truly beautiful effect.
About the expressed angst of some who worry about hard drawer sides running on soft wood, I can only wonder why anyone would take the trouble to make a nice Hardwood furniture piece and use softwood for the interior structure.
Using softwood or softer then the drawer wood is a minor cost savings .
Using hardwood of a lesser quality then the case for dust panel supports and dividers eliminates the perceived problem.
FredD
Re: Drawer material
Wonder if you will, but....
Bill Tindall
yellow pine, poplar and white pine, and even white cedar (from shingle stock) are the woods to be found in period pieces selling for up to millions of dollars.
Re: Drawer material
Re: Drawer material
Larry in NW OHIO
Dave As I said yesterday, I mostly use Baltic or Blondewood ply for the drawers, but also poplar. If you need any poplar I have quite a bit left over from doing the kids builtin bookshelves. So if you want some I can let you have it cheap, since it was all off fall and I don`t have use for all I have. I`m sorry I wasn`t to sociable yesterday, but I was in quite a bit of pain because of the rain and dreary day. Let me know about the wood, also if you do it with ply, I have quite a bit of iron on stripping to cover the ply look. Larry
Re: Drawer material
Clint Searl
Re: Wonder if you will, but....
Clint Searl
I guess those period furniture makers didn't realize they were making "fine" furniture. At least they didn't use MDF. :b
Clint
Re: Drawer material
More on cedar
Bill Tindall
I was on a tour in the Philadelphia museum with the conservator and a question was asked about drawer construction. Drawers from various time periods were removed for examination. During one time span (mid 1700's? I can't recall) the drawers were made from white cedar(with mahogany fronts of course). That seemed to be an extraordinary choice but then it was explained that cedar singles were being imported from the north. These shingles were of ideal size for drawer parts and they were utilized by the cabinet makers.
One of the signature pieces from a later period had a red cedar back.
Re: Drawer material
FredD
But not the only woods and for the pieces you find with softwood , it in my opinion is because given the tools , lack of Expensive wood and the well documented fact that drawers in many cases used scrap , some of them only rough sawn and like the Nightstand I showed that was from Luxembourg and I restored , the sides and backs of the drawers were all different thickness , even the drawer sides didn't match.
The effort was expended on the drawer front.
Pine was popular at the forming of this country , because we had a ton of it and it was easy to work with and pieces from that era that were in everyday use are few and far between because of the softwood's lack of resistance to wear and tear.
People that pay huge amounts for allegedly antique furniture are the same ones that pay fortunes for ho-hum paintings and are indulging themselves in a typically American pastime of "mine is bigger and better then yours".
The most popular wood for Colonist's was Pine because it was easy to work.
Probably also the reason , not many pieces survive that were in everyday use.
FredD
