Working with prefinished Flooring????
Getting ready to install some prefinished Brazilian Cherry Flooring. It's from Lumber Liquidators and has their fifty year finish which I assume has aluminum oxide in it. I also assume this finish will be hard on tools. We want to lay some patterns which will require more cutting and routing than usual. So, any advice? How quickly will it ruin carbide router bits and saw blades?
Re: Working with prefinished Flooring????
Andy Halterman: Carving the singletrack
There really isn't enough finish on the boards to affect the blades/bits. The wood itself will do much more damage to the cutters. I'd suggest having a second good blade and bit available so you can keep your cuts clean. Braz. Cherry has a way of eating up carbide.
Have fun and make sure you use cleats instead of staples in the big nail gun. Staple just end up splitting the tongues on really hard material. Cleats go through much more cleanly.
Andy Halterman
Night riding season is in full swing in Hendersonville, NC�
just got back from there and
Bill Tindall
I saw lots of apples but no night riders. So what is night riding?
FredD
The fifty year finish is BS , unless no one walks on it for fifty years and the company is still in business to honor the guarantee.
I have laid a lot of prefinished flooring and it sounds like you didn't get or want end matched and edged beveled which disguises the ups and down you going to get at the ends and the prefinish will not let you sand it level, which is the reason for end match and edge beveled.
The floor sales people will tell the client when they trip over the end joints that it is customary to allow as much mismatch as the thickness of a credit card which is total BS. Lots of luck, Brazilian Cherry is a nice looking floor material and hard and heavy.
FredD
Finish doesn't matter
hoa
I've just finished laying down about 1000 sq. ft. (300 sq. ft. more to go) of pre-finished flooring (Santos Mahogany). The finish is aluminum oxide.
I don't think the finish makes much, if any, difference in terms of wear and tear to saw blades.
Laminate flooring is another story....
This stuff is end matched and has "micro" bevels. Micro being about a 1/32" as opposed to 1/16" or whatever hey put on the Bruce version I put in my house. You are right about the fifty year finish. Advertising hype. I hope it better than the finish on the Bruce stuff. That had the "outta site" finished. It lasted until the trash truck carried the boxes out of site. I hope Bruce does not make ANY longevity claims. Their finish is crap. No, Really Crap.
Larry in NW OHIO
Please excuse me but I`m pretty slow,or I just missed something, what is the Bruce finish? Larry
My Bad.....
Bruce is a brand of flooring. Its pretty big locally and I thought "everybody" knew what it was. Its a big country and not one world.
Bruce sells lots of different types of prefinished flooring and my experience is that the finish is crap.
Got the same stuff 7 years ago
Ray - Middletown, IN
for my office and hallway. Shows zero wear so far but it did scratch under my stationary bike. It does change color, much the same as American cherry, probably quicker though. If I use it again I will spend some time doing a better job of color matching. Tool wear was not a significant factor, the flooring guys noticed no difference compared to other flooring types, we did have that discussion because of the finish contents. I did make some custom transition pieces and it does machine decently, just watch grain direction for splitting. It does split badly when nailing so take care and pre-drill any face nailing. Clean occasionally with vinegar water and you are good to go.
Ray
FredD
The biggest problem with Bruce flooring , is one they created by being a old line well respected Floor finish manufacturer and wanting more, they jumped into the flooring game by buying from flooring mills the profiled product and subbing out the finish on the wood to some other entity, so you get all different levels of quality from them, because of the different mills and the price point Bruce is aiming at.
Beyond that it doesn't help having a discounter like Home Depot and Lowes get in the mix.
FredD
