OT-Emergency plumbing repair ?
Alan Young
I was checking out the plumbing lines in my house this evening because I am planing a fairly major project, It seems this was good time to be looking around as I saw this pipe in the laundry area in the basement.
As we are having a crowd of people here on Thursday, I need a quick fix. You can see there is a shut of valve right there but I'd rather not try and remove the damaged pipe as I anticipate a fair amount of difficulty getting it loose-if not at the end shown in the picture-then at the other end-(I didn't take a picture of the other end)...I was thinking of wrapping a rubber hose around the pipe and hose clamping it till I can replace the whole pipe. I'd have to cut a slit down the tubing then wrap it around the pipe with the slit on the opposite side of the rusting spot and hope that the hose clamps can draw the slit tube together. Any other quick fix solutions?
-Alan
