Shower mixing valve
Shower mixing valve
Shower mixing valve
Tom Dunlap
I've stayed in my share of hotels and taken showers at friends places. It seems like once the hot water has made it's run to the valve it should be quick to adjust the mix with single lever mixing valves
But, it seems like sometimes it takes 'forever' to change the heat...so I turn the valve a little more..then get scalded?
Why is there such a delay sometimes? There can't be that much of a restriction
Tom
Re: Shower mixing valve
Jason Roehl in Lafayette, IN
It has to do with the flow rate of water to the mixing valve compared with the volume of water in the pipe between the mixing valve and the shower head. Many shower heads nowadays are low-flow, but the pipe coming out of the mixing valve is 3/4", so it takes a few seconds to run the water out of it.
Jason
Behind the wall
Tom Dunlap
that makes sense...now you gave me a second question.
Since some showers have instant heat change and others are slow what would the plumbing look like? Why the difference?
Re: Behind the wall
John McGaw
Typically it isn't the valve, it is the pipe. If you have a long pipe and the hot water has been sitting in it for a while, it is no longer hot. When you turn on the hot and cold (shower, tub, sink, whatever) to get warm water you are then mixing cold with cold until the replacement hot water from the tank has traveled to the mixing valve and even then it will be a bit cooler than normal until the pipe itself physically heats up. As soon as that happens you are mixing cold with hot and getting your warm water. It is especially noticeable in my home in the kitchen which is at the opposite end of the house from the core where the water heater resides. It is almost unnoticeable in any of the three showers because they are near the core.
In a large hotel or motel it may be less of a problem since the odds are that someone will have the hot water running somewhere along the trunk keeping the water up to spec. More modern plumbing installs a loop for the hot water which has a small pump which moves water from the far end of the line back to the tank all the time so that there is no delay waiting for hot water to get to the valve. I would consider doing that myself except that running the extra water line would be a real killer job.
Re: Behind the wall
Stuart Johnson
The valve we have has some sort of temp gauge inside so it can only be so hot. It might be it takes the gauge time to adjust.
Re: Behind the wall
Joseph Mulherin, Sr
When I was an apprentice plumber we used to run a 1/4" line from the heater
to the upper lavatory and let the circulation be by the difference in temperatures...hot rises and cold decends back to the heater. The line was connected to the drain valve at the bottom of the heater.
Running this line in an already finished home would be a problem but could be done if someone wanted to open the walls a little.
Re: Behind the wall
Larry in NW OHIO
John There is a place that makes a pump that circulates the hoy water when it cools off and it brings the hot water to the sink. If your interested go to www.lainginc.itt.com. Larry
