dc bag repair
Gerald Gibbs
put a slit in my plastic dc bag. cleaned with alcohol. blew the duct tape right off. any suggestions until I get a new bag? now that i finally have a dc, i like it. jerry
dc bag repair
Gerald Gibbs
Re: dc bag repair
DavesNotHere
Got a heat gun? You might try overlapping the tear and then use the heat gun to melt it together. Or, go to any hardware store and buy some of those 3 mil thick contractor trash bags and use that.
Re: dc bag repair
Larry in NW OHIO
Just another shot in the dark, maybe duct tape inside and outside and try putting 2or 3 strips aside and overlap a little. Larry
Re: dc bag repair
Jesper, Denmark
Maybe use packing tape in place of duct tape, it seems to stick better.
Been there, done that
Neal in San Jose
There is duct tape and there is duct tape. Most of the stuff you get in the big box stores isn't very good. Much thinner than it used to be and less aggressive adhesive. Then if you do get it to stick to something, in a short while it will dry up and fall off.
I've successfully used the metal duct tape that comes with backing tape. It is more expensive and may be a little harder to find, but it actually works. Cleaning with alcohol as you did helps.
gorilla tape will fix it *LINK*
del schisler
here all about gorilla tape verse duct tape
http://www.google.com/search?hl=en&source=hp&q=gor
