Removing gasoline smell....OT
My son, Sasquatch, spilled the gas/oil mix for the chainsaw in the house we are working on. Spilled a half a cup or so on some new OSB. I was not there at the moment. He says he mopped it up as best he could with paper towels and then covered it with sawdust. Today, we cleaned up the sawdust and put baking soda on it. It still stinks.
Any suggestions on removing the smell?
Re: Removing gasoline smell....OT
Howard Norman
You are never going to get the smell out of the piece of OSB in my opinion. For the general removal of the smell I think that air is your best bet. Open the windows and doors while you are there and just let the place air out.
Bill Tindall, E TN
I think you reported that this will be his house so there is no need to remove it completely. I can be a reminder to be more careful.
But, if you must:
There is no way to extract it completely, so don't waste effort trying. I would simply remove the sheet of OSB and replace it. Alternatively, heat will volatilize it eventually. If you have a portable heater direct a blast of hot air on the offending area and eventually it will all go away except the oil which is there forever.
Ken Oakley-Sunny St. Cloud, Fla
Lock twelve cats in the house for one week. You will never notice the gasoline smell again
BArry it won't hurt to try. Pour lots of Baking Soda on it and let it sit for several days or longer. It has worked for other things for me.
Chuck Kettler--Greenwood, IN
Please, please, follow Bill's guidance. Understanding chemistry makes a difference and if you really believe that the oil will not remain, please think again. So easy to remove a sheet of anything vs pull up something and realize you missed the boat later.
John Veerkamp
Barry,
You might try White pigmented Shellac. Several brands on the market, Kills and Zinser come to mind. It is what professional restorers use to seal in smoke damage. Might work on this also. Worth a try.
Larry in NW OHIO
Barry If you can just remove the SOB board and be sure it`ll be rid of. Then it`ll be done with. Good luck Larry
Dave Bair, Eaton Rapids, MI
Or try Seal Coat shellac if you don't want the primer look. You may have to coat both sides of the OSB.
