Carpet Tape Frustration
Bartstar
I was looking to buy some basic, cheap, double sided carpet tape at the local big box stores and did not like what I found. One brand has a "plastic film" type cover over the tape that was a real PITA to remove. Another used some kind of sticky substance as the substrate and was nasty to get off - it was all gummy. I need the basic old fashion kind - paper between the layers and a paper substrate. I am ready to order on-line since neither Lowes or HD had the more traditional stuff. So, I'm looking for brand suggestions.
Thanks
Bart
Re: Carpet Tape Frustration
Not Carpet Tape - No Frustration *LINK*
Hoa in Alameda
Carpet tape brings frustration. Don't by carpet tape ;)
Double-sided tapes are equal. Some are just more equal than others.
Buy cloth double-sided tape. I bought a few rolls from Hartville Tool a while back and am still using them.
Double Stick Tape - 1"
fred in ct
You can get the double sided tape you describe at a golf store that sells golf grip supplies such as Golf Galaxy or Golfsmith.
it must be a local thing
Lee Schierer McKean, PA
I like the thinner carpet tapes and even the gummy residue one is easy to clean up with a rag and lacquer thinner. However, none of the three local borgs carry anything but the thick fabric type double sided tape, which is too thick for wood working purposes.
I prefer the 3M acrylic adhesive tape as it has a high bond strength so yo don't need much tape and it removes easily as long as you don't leave it in place for a long time. I haven't found a local source or online source for this tape in quite a while.
Lee
Keith Newton----Little Rock, Arkansas
I like the cloth core the best, and think the plastic film core is worthless.
As for making the film easy to remove, I start by pressing the end of the roll down onto the work or template, then with my knife start my cut 1/8" from the edge, and pull the roll away, stretching the un-cut portion until the paper breaks. The paper will also come loose under where it just broke.
With the same knife, I slip the tip under the paper, and peel it back, before cutting the final 1/8". This only take a second every time.
Now I wish I had a good method for plastic packing tape, for the times when I forget to fold the end back onto itself.
paul woolson
Uline has AMAZING stuff. It's not carpet tape. But double faced masking tape. I was skeptical until I watched another woodworker turn a bowl that was held on with this tape. My initial thought was, "dang, that was stupid". But then he had me try to get the stock off of the chuck off. I honestly couldn't do it. Then he slid a pallet knife between the chuck and stock and worked it loose. I took a lot of work but it came off.
So I bought a case of it and use it all the time. It doesn't leave any kind of gummy residue. And it's much better about not tearing fibers from the wood than carpet tape is.
Give it a try. I think you will be pleasantly surprised as I was.
Larry in NW OHIO
Paul Never heard of it, where would a person get it, Thank You Larry
paul woolson
Uline is an online shipping supplier. Here's a link (assuming I can make the link work)
http://www.uline.com/BL_3117/Double-Sided-Masking-Tape?keywords=Double%20Sided%20Tape
