What to do with old bandsaw blades?
wilbur
I think I have finally come to the end of the useful life of a few of my bandsaw blades, and am replacing them. What I don't know is what to do with the old bandsaw blades. I really am inclined to cut them into short lengths and toss them into the trash, and I am not really that much into tool making.
Any ideas before I toss them out?
Re: What to do with old bandsaw blades?
Clint Searl
Clint Searl
I seem to remember an article in FWW from many years ago that highlighted a wooden bow saw with a blade that appeared to be a section on bandsaw blade. The craftsman featured, demonstrated cutting dovetails with it using the blade twisted 90 degrees in the frame.
Clint
Make shedding blades for horse and dogs. Blunt the teeth with a file. Cut the blade into a number of increasing lengths. Make a "banjo" or "lollipop" with several of the lengths. Put some "scales" on the end and drill and fasten the scales together.
The shedding blade can also be used as a "poor mans" rasp.
Great Design for a Back Scratcher
see if you could make this. *LINK*
Roy Anderson
see link--Japanese saw rasp.
Japanese saw rasp
Re: see if you could make this.
Marv
Roy,
Think I'd just buy the rasp and go ahead and toss the bandsaw blade.
Marv
Kneale Brownson
Check area schools?
Kneale Brownson
I used to take both wood and metal cutting band saw blades to the local school's shop department. They used them for practicing blade welding/sharpening and for making things like the other uses described here.
Roy Anderson
Same here, but he asked, so I thought I would throw out a challenge.
Jim Pugh
Why not just take them to your metal recycle place? Maybe they'll end up as a new blade someday.
Toss them
John in NM
If you want to save some for scratch stocks or something, just save a foot or so. You can break them using two crescent wrenches. Bandsaw blades are so cheap there's little point to trying to re-use them, like scrap wood, I always seem to have an old blade or two around.
Don't just Toss them
R Payne
If you don't want them, either recycle them (you may get a couple bucks) or find a local blacksmith you will use them.
ron
They make really Great
Merle
dental floss for wooden dentures!! :D
