200+ woodworking book reviews
Delta Super 900 radial arm saw
Carol Reed, Strawberry, AZ
I am in the market for a radial arm saw for a dedicated purpose. I have found three of the above at a price I am willing to pay.
Anyone have any experience with this particular brand and model? The angle adjustment pivots from the middle of the arm, independent of the height adjustment. Sounds like a good idea. the saw was manufactured in the early '60's and listed as a 9".
Re: Delta Super 900 radial arm saw
Re: Delta Super 900 radial arm saw *LINK*
Grant in Iowa
Hi Carol,
I cut my woodworking teeth on a Rockwell/ delta Super 900 radial arm saw.
I bought mine without a table for $60 back in the early nineties. With a bit of elbow grease to fine tune it, it made a lot of nice furniture before I got a Unisaw.
The turret style arm is in my mind a superior design to the simpler and cheaper rear swivelling style. The design means that the blade is closer to the center of the table on deeper angle cuts. Further, it allows a larger range of motion and combination of cutting options.
The machine is the real deal. Cast iron throughout and all joints are adjustable and alignable so you can enjoy a nicely accurate machine. This is NOT one of the machines that gave Radial Arm Saws a bad name.
The saw is a 9" saw, meaning the blades are 9". It will not accept a 10" blade. I bought two blades, both thin kerf freud 9" blades. One was for ripping, and one for crosscutting and sheet goods.
Step one with one of these saws is to get rid of any play between the saw carriage and the arm. This unit has 4 bearings that ride on grooves in the arm. The bearings on the right side of the carriage are mounted on eccentric bosses, and as such can be adjusted to remove all play and flex in this area.
The turret should lock tightly when the lever is tightened. A spring loaded pin is raised to allow arm swinging movement, and will snap back into detents at 90 and 45 degrees on each side of zero.
The column also has adjustable brass shims to keep it at 90 degrees and free from flexing left or right.
The benefits of these saws is the "one machine" do-all aspect of them. They can be dangerous if used improperly. In a well equipped shop, they can assume the role of dedicated crosscut machine, since they have a wider capacity than your average SCMS.
I did replace the arbor bearings in mine after about 8 years of use, but I was able to do this myself with bearings from a bearing supplier in about an hour with no pressing necessary.
Nice quality machine.
I did recently sell mine because I found i just wasn't using it any longer. I have a large 12" Sliding Compound Miter Saw now and the RAS was just gathering dust.
You can get a manual for one at the below link. Here is the procedure to align the miter stops (and 90 degree stop detent):
http://www.owwm.com/pubs/1141/2841.pdf
Here's a manual for a 1962 Super 900:
http://www.owwm.com/pubs/detail.aspx?id=513
FWIW,
Grant in Iowa
1958 Super 900 manual
Thanks, Grant. I am assuming the shaft is long enough for a stacked dado set. That is a criteria for me. I'll post a gloat in due time, if I pull the trigger.
please humor my curiosity.....why?
Bill Tindall
I have long regarded radial arm saws as obsolete tools, replaced by versatile table saws and less expensive chop saws. I never see them in use in shops any more. What use have you found for such a device?
Good industrial grade used ones can be had for little.
Re: please humor my curiosity.....why?
Howard Norman
Bill, I assume that you mean commercial shops since I can show you at least two of them here in this little community and there are probable another dozen that I don't know about. Admittedly the two that I am very familiar with are in hobby shops, my shop being one of them. Mine is an old Craftsmen purchased new in the 70's. It doesn't get a lot of usage but I would not be willing to get rid of it. It was the first stationary woodworking power tool that I purchased.
FredD
Carol , that particualr model in RAS for it's size was a Cadillac of saws for it's well designed all cast iron body .
What Grant said said about it is certainly true , I have used that saw in many Cabinet Shops ,nearly all of which used it as a dedicated crosscut at which it excells.
Not to belittle Bill's remarks , but a good RAS like the one your looking at in the hands of a person who is well experienced will put any SCM to shame for crosscutting to lenght and ripping as well.
For those who admire sliding compound saws , FWW e-site has a review on the new Bosch which is top of the heap for that type saw and at only 800.00......
It depends on what your thinking of to use it for.
For ligthweight cross cutting to length , same for trim you got a dandy.
If you need cross cutting of stock like 2" thick or larger hardwood , think of a second hand chopsaw.
FredD
Re: to humor Bill
I have a rather large commission that will require miles of dadoes. This machine will become a dedicated dado machine. It will be way faster than a router. The dado blades will last way longer than a router bit. The set up on the saw will be very much quicker. And the actual milling will be done with pneumatics operating the saw. Much safer and bunches easier on my badly damaged back and neck. As we get older and more feeble, we have to get more creative and crafty. Or we have to stop doing teh things we love.
I think I will name this project saw "Norm." I was inspired by the many times I saw him mill dadoes with his radial arm saw, though he did it manually. I can't fo that for very long anymore.
With regard to SCMS's. I have two and don't plan to get rid of either.
And finally, I am doing this because I can.
I am not offended by your observation, Bill, but I hope your itch has been scratched. LOL!
yes indeed
Bill Tindall
Thanks, curiosity satisfied. Indeed there is a use for these dinosaurs that makes sense. I knew you would have an enlightening answer that I hadn't thought of.
Grant in Iowa
Carol,
The Super 900 will indeed accept a stacked dado cutter. If memor serves, going to 3/4" will require the omission of the arbor washer.
It should also be said that this unit is rated at 1 HP, it may be a bit underpowered for production dados.
A better choice for that application would be the similarly built larger turrett style Delta 10 and 12 inch saws.
I used to use mine for dados, but the feed needed to be careful and slow to prevent overloading the motor.
FWIW,
Grant in Iowa
Good to know, Grant. I can vary the speed of travel with the pneumatics. I am also trying to figure out how to automate the height mechanism. Now I'll add step capability to that, if I can. I could then take the cut in two passes.
The speed comes in the setting up for the cut, not in the actual cut. The control panel of this thing is really gonna be something!
Mark Mallia
Nothing beats a radial for high end box miters. An SCMS is fine for mitering picture frames or trim(or rough cross cutting, what I use mine for). You can cut good miters on a table saw, but it's slow and cumbersome compared to a perfectly adjusted radial with a calibrated fence.
Robin Corell in Atascadero CA
Your plan sounds solid. In addition to considering the larger version I would also suggest picking up a second saw just so you can have a spare motor. The motors on these things are built like tanks and rarely need anythng more than new brushes ( or just resurfacing the old ones) but when they do no one will have parts siting on a shelf. It would be a shame to have your spiffy new dado center shut down waiting to locate replacement parts.
That said, every pattern shop I ever worked in had a large radial for breaking down large boards. They were always rather sorry looking but they always worked and were alweys acurate.
Robin
Ps, don't forget a radial reqires a negative rake tooth.
FredD
Robin , I am glad you didn't forget the negative hook factor , because I did and it is really worth thinking about .
I don' believe I have ever seen a off the shelf Dado unit with a Negative hook and since the bite is much larger it really would need one.
Every Time I use mine on the RAS I stiff armed it and kept the cut shallow.
FredD
That is the reason for the pneumatic cylinder - to advance the saw motor through the cut with total control and my arms are spared the effort.
I have an 8" CMT dado set. I would be loath to have them reground for this purpose. I will try them with the pneumatics and then make a decision regarding the need for negative rake.
FredD
I would be interested in seeing the results of this adventure.
FredD
