Cardle repairs
Rich in MN
I built a cradle 5 years ago and it has been used for several babies. Now my daughter is expecting and they tried to put it together and found some the brass threaded inserts have come loose. Some one must have over tightened the fastners and spun the inserts.
What is the best way to secure them so that the cradle can be assembled and used?
I did a test with Gorilla Glue but it didn't hold.
Will an epoxy work or do I need to drill a larger hole and insert a dowel and make a new correct sized hole for the inserts?
