We value your privacy.
I just saw Barry Irby briefly mention cleaning his Performax drum sander paper with Simple Green.
Really? This would save me some serious coin. Can anyone elaborate on how this is done? what type of container, how long to soak, rinse, etc... would be helpful.
Grant What Fred does good, except fpr the really hard stuff. I use SG for that. I use an old plastic coffee container, it`s just the right for one rolled up Woodmaster sanding roll. I mix it about 3 water 1 SG in the container, roll the paper just enough to fit in the container, put the lid on and let it set for maybe a day. Take it out and put a screen on top of the container and put the rolledup paper on top to drain off. Unroll it blow it off, both sides, and take a not to stiff a wire brush and clean anything off that may not have come off, and hang to dry for a day. They do curl up from the sides but it does not hurt. Good luck. If you have any other questions just ask. I`ve been doing this for years. Larry
I've tried Simple Green on my 22-44 abrasives, but if I've gotten a "burn streak" (usually happens with cherry), I'll need to use Easy-Off oven cleaner to get the residue. If you don't get them really clean after a burn, they'll just reload and burn at the same point fairly quickly.
For on-machine cleaning I use a gum rubber block and/or a scrap piece of Plexi-glass also does well.
The gum stick works pretty well imo, but I doubt legal depts. allow this method to be suggested by manufacturers of either machine or gum stick. Matter of fact, there are liable to be instructions showing a pic of a stick with a slashout on it. Buy 2 sticks. You only want to be using long sticks for this application.
I do pretty much what Larry does. I have an old One Gallon plastic jug and put some water an SG in it. Probably about 1/3 SG but who's measuring? I roll up a belt or two and put them in and let them soak for an hour or more, sometimes a few weeks if I forget. On my double bowl stainless steel kitchen sink (I live alone, can you tell?) I put the strip face up and use a nylon brush to brush off any remaining crud and them flood it with water to rinse of the SG. Then I hang them up in my shop, with the top clamped to a light fixture and another clamp dangling from the bottom to keep the straight will they dry.
It takes less time to do than it did to type this. I have done some over and over. I built a project out of heart pine and if you could get a four foot piece through the sander, it was clogged. Really clogged. Washing those in SG saved them from being one hit wonders.
The only downside I know of is that it washed the makings off some of the belts. Use a permanent magic Marker to label the grit size if you care. When the "mud" gets too deep in the bottom of the jug, I pour off the SG, flush away the mud and put the SG back. Lasts a LONG time. I'm cheap.
