Cleaning Saw Blades
Ed Freestone
I have two carbide tipped Freud TS blades and steel dado set that have a fair amount of crud built up. What do you folks use to clean your blades?
Thanks,
Ed Freestone
Silver spring, MD
Cleaning Saw Blades
Ed Freestone
Thanks,
Ed Freestone
Silver spring, MD
Re: Cleaning Saw Blades
Dale Lenz
I've used Easy-OFF oven cleaner for over 30 years, yellow can, works great! I'll probably get trashed over this one as many folk claim the EO eats the binders that hold the carbide to the saw plate. I never forget about when I apply the EO and scrub(wipe) and rinse the saw blade off in 15 minutes or less. TSP works good, also
Simple Green
Neal in San Jose
Easy, cheap, safe, fast. What more could you want? I cut the bottom two inches off of an old 5 gal paint bucket, which just happened to be the right size but you could use just about anything, toss in a blade and a cup or two of mixed S.G., wait about 15 minutes (or two days if I forget), and scrub off the crud with a nylon bristle brush. I get the S.G. at Costco in bulk (cheap) and it is reusable if you want to go to the trouble to save it (really cheap).
Re: Simple Green
I bought a spray bottle of blade cleaner from Wood Craft (CMT?) and it work great. lay the blade on a piece of plastic sheet spray, foam spray, soak a few, wipe clean, touch up a spot or two and move on. Sort of odd odor but not offensive and did not seem to hurt my skin.
Having said that, I think I would use Simple Green now that I have it to clean the sanding belts for my Performax. A small round pizza pan or cookie sheet works well.
Generic solution
Bill Tindall
Anything basic will readily dissolve blade pitch. Oven cleaner, ammonia, TSP, and many cleaners are basic so it follows that all these things clean blades readily.
Freud claims that things basic will attack the carbide. The details of what Freud tested were unknown to the people in the Freud booth at IWF. I have been unable to confirm this claim with reasonable cleaning times and concentrations. Never-the-less one should consider their warnings and at least minimize soaking blades for extended times in concentrated chemicals.
One advantage of household ammonia is that it is colorless. Any attack on the blade metals by ammonia will yield an intensely colored product so at least with ammonia there will be a warning if the blade is suffering.
The acidic wood pitch will attack carbide and promote dulling, so don't let this stuff build up and stay on carbide cutters.
Re: Simple Green
Larry in NW OHIO
Amazon has something called Blade saver made by "EMPIRE", I use it and it does a great job and quickly. There are other things that are cheaper such as, Arm and Hammer "Super Washing Soda" that you can get almost any grocery store. It`s cheap and works fairly fast and it`s safe. Larry
Re: Simple Green
Dave Bair, Eaton Rapids, MI
This stuff will also remove all the text on your Freud saw blade; not a big problem, but you should know. The red blade coating is unaffected. The other methods may also remove the text.
Re: Simple Green
Bill Howatt
I write on the blade with a vibrating tool a description such as Freud, 40T, ATB or whatever it is.
Bill
No to Simple Green
Howard Acheson
Here is a thread on another forum that contains a statement from the manufacturers of Simple Green. Standard Simple Green should not be used on saw blades.
Fantastik -- it works great
AZ in Colorado Springs
