Re: Advice/opinions requested...
Brint in Richmond, VA
Thanks so much to everyone for your responses. I've done a lot of reading (books, magazines) in years past, but nothing beats having a bunch of experienced hands answer precisely the question that one is asking. I was a bit surprised to discover that most people consider both a dado blade and a router bit for different situations. I suppose I had expected answers more along the lines of "pins first/tails first" discussion. ;-)
Bill -- I do plan on learning dovetails (as well as becoming more proficient with hand tools). I wanna knock out just a couple more rabbeted joints before proceeding to the next skill level. ;-)
Bart - you (and others) mentioned a couple of post-glue-up considerations (tweaking, sanding, etc.) that I had forgotten about; thanks for the reminder.
John - I appreciated the distinction between complex and simple builds. That's a good nugget of wisdom I would not have thought of on my on.
Colonel - Yes, marring the finish on glue-up is something else I hadn't considered. (and thanks to you and Bill for the affirmation of the wood - !)
Larry - I always enjoy hearing the "minority" report, and the reasons you give certainly fall within my realm of "expertise" (or, more accurately, lack thereof). I'll definitely keep your comments in mind.
Steve M. - the orthopedist yesterday told me I can expect to get one, maybe two more years out of this hip, and I'm afraid a trip to the optometrist for bifocals is the next appointment I have to make. [blink blink] Noted.
Steve in P. - hadn't thought about using the compressed air. Will certainly do that. Do I need to use a grain-filler, then, before finishing?
Fred - thanks for sharing the "practices of the pros" - that's good to know. Also, I used a Grizzly-issued blank insert made of a composite of some sort to make the zero-clearance for the dado blade (my TS is a second-hand Grizzly 1023Z).
Again, thanks to everyone. I'll post pics when I'm done.
