Bonding Aluminum To Concrete
Tom Rex
I�m still trying to get my tools from the garage to my driveway over the expansion joint.
I wasn�t happy with the idea of putting bondo in the joint.
So I purchase a sheet of aluminum that is 6� wide and 48� long.
I think this will work well but I need to make it so the aluminum doesn�t move.
Any ideas?
Thanks,
T Rex
Re: Bonding Aluminum To Concrete
John Veerkamp
construction adhesive.
Tom Rex
Can you be more specific?
What's the brand name, etc.
Thanks,
T Rex
I am working from instinct here, but I don't think construction adhesive will work for long. It you are in a climate that freezes, gets rain and gets hot, bonding anything to concrete will be tough.
I would mechanically attach it with screws in anchors like RedHeads, lead anchors, or even plastic screw anchors. And I would only fasten one side and leave the other edges free to float in case the expansion joint does its thing and the concrete sections move in relation to each other.
Gerald Gibbs
I used clear silicone to bond painted plywood in a similiar situation in MI. It is still holding a year later. Jerry
John Veerkamp
PL2 is one such adhesive. Or Liquid Nails for Sub-Grade. Your local hardware store or borg will have a selection. Get one for sub-grade(wet) conditions.It will hold well even in freezing and thawing conditions.
AZ in Colorado Springs
I'd guess your garage floor has a smooth surface, smoother than the driveway. Use duct tape to secure the aluminum to the garage floor, where it will bond better to the smoother concrete. Lay the first strip across the edge of the aluminum sheet, then add two additonal strips overlapping each side of the first strip. When they get worn, it'll be easy to add a bit more duct tape. (And if the aluminum proves to be unsuitable as a bridging material, it'll be easy to remove.)
I'm with Barry
except I'd consider Tapcons.
something reversible without a lot of hassle, at any rate.
Is this a permanent thing or will the aluminum be removed once you have everything moved. Clear Silicone caulk works wonders for bonding things together. It can be fairly easily removed with a putty knife or other slim piece of steel.
If you need something that's permanent then I would check out an epoxy called PC7. At least I think that's the name. It's usually sold in hardware stores and comes in 2 plastic 35mm film cans. We used to glue rocks on cinder block walls to make a climbing wall with the stuff. After 3 years of people climbing on the rocks they decided to use the room for something else. We had to chip the rocks off and it still pulled out some of the block. I've heard that it is the same stuff they glue the reflectors down to the asphalt roads with. I don't know that for sure however.
Larry in NW OHIO
Tom Just a thought, if you end up using Tapcons, I think I would consider flat head type. That way you would not have the heads sticking up. Larry
Tom Rex
I solved this problem by
getting a 12 X 24 inch piece of aluminum
cut it in half to make 2 pieces 6 X 24.
drilled holes in the middle of the ends of each piece
chiseled out a hole 1 1/2" wide by 2" deep in the expansion material
cut 4 pieces of wood 1 �� X �� by 2"
pounded a piece of the wood into the hole
screwed the aluminum to the pieces of wood.
We�ll have to wait & see if this holds up.
Thanks for all of your tips,
T Rex
Every Solution has it's Problems....
That's how the ancients split stone. Pound dry wooden pegs into holes and give Igor a watering pot to keep them wet. Wonder if Mother Nature will provide enough water to swell the pegs and move the concrete? Actually, I think it will work. Hope you used treated wood so it won't rot. Hope you used screws rated for treated wood so they won't rust away.
