Re: Air drying question
Grant in Iowa
Hi Brian,
Congrats on the wood haul. I have been drying lumber for about eight years now and I think I have the basics pretty well down.
Conventional wisdom is that for the first few months, the lumber should be stickered and stacked outdoors but covered in order for the majority of the moisture to be released and dissioated in the air. The main reason for this is that the amount of moisture given off by drying lumber is significant, and can create ill effects on surrounding items if the drying is done in a confined space with little air movement. Further, that same moisture can cause molds and mildews to grow on the damp lumber. You need air movement to evaporate moisture as it comes to the surface of each board.
With a small amount of lumber, you can succesfully dry it from the get go inside an enclosed space, so long as you keep air movement going and have a regular air exchange with the outdoors. I have successfully dried green lumber in quantities under about 200 BFt in a 3 car garage with no noticeable issues.
I tried 1100 BFt of green lumber inside my 1400 square foot shop last year, and while the humidity in the space never raised appreciably, I did have a touch of fungal growth on the lumber in the center of the stack. To his credit, Ellis did try to tell me drying that much lumber indoors was a mistake. Lesson learned, I will dry large stacks of lumber outdoors and under a cover from here on out, at least until it is nearly dry.
I suggest your shed would work if you could leave a door open, for air movement, or perhaps run a small fan to circulate air if it is a drafty building.
Best approach is either in a corn crib or similar shaded, well ventilated structure, or outside in a shady area with a wide roof over the top. I made up a sheet metal "roof/ sunshade" about 3 feet longer and two feet wider for drying lumber outdoors. After about 2-3 months, you can move the lumber into a building, but still sticker and stack it for another year or so (for 4/4 lumber). Alternatively, you can have someone kiln dry it for you after it drops below 25% or so Moisture content.
The idea is an area with air movement, out of direct sunlight (or build a roof to accomplish this), and a flat surface so the boards dry straight. You want the moisture out of the wood, but not too fast or too slow. A damp shed with a muddy dirt floor would likely be too slow, while an uncovered pile in direct sunlight would be too fast.
See my lumber stack method and roof below. Note the wide overhang on the roof tin on the right side and ends to limit direct sunlight. This is a total of about 1300 BFt of Cherry, Walnut, and red oak drying next to my shop since about May of this year. My pin type moisture meter now reads around 10% MC, but this doesn't mean the moisture is evenly distributed throughout the lumber yet, which will take another several months to occur. It would be premature to try to use it until the internal moisture is at equilibrium. At this point, I could move it inside, however, as most of the moisture is gone at this point. As such there is little risk to surrounding objects rusting, or of fungus growth/ sticker stain.
Hope I have answered your question in a round about way.
Regards,
Grant in Iowa
