Cottage Movies, Converting from VHS ??
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Hi,
I just found a few Cottage movies and one from a memorable trip to Windsor Ont. I'd like to convert them from VHS so I can have them on my PC, even upload to Youtube. Does any one know how to convert VHS to a computer file?
Thanks
take care,
Jim
Re: Cottage Movies, Converting from VHS ??
Re: Cottage Movies, Converting from VHS ?? *LINK*
Bill Howatt
Play the tape into a video capture card in your PC. Now, most PC's don't come with them so you'd have to buy one. Can be internal or a USB. After you get it onto your computer you then need a program to burn it to a DVD in DVD format if you want that. You can leave it as mpg format and a lot of players will play mpg files directly. This is an area with lots of methods, formats, wrinkles and frequently opportunities to use new words!!!
Here is a link to various devices. You'll see some are cheap and others aren't so cheap. Make sure it is supposed to work with your hardware and operating system.
Places like Future Shop and your local computer store also sell them but you might find somebody nearby who can do it for you if you see this as a one time thing.
Bill
Canada Computers Video Devices
Dave Paine
As Bill mentions, a PC is the normal equipment for this conversion.
In addition to the Video capture card, please be aware your PC may not have enough muscle to edit the resulting files. It should be able to burn the files onto DVD's, but editing is another matter.
I bought my wife a HD video recorder for last Xmas. It turned out her PC was not able to run the HD edit program which came with the camera. The weak link was her video card.
VHS is much lower resolution than HD, but this was a surprise. An older PC with "only" 512kb of RAM will struggle to edit any video.
Joanne in Point Pleasant, PA
Hmmm. I have my Dad's combo vhs/dvd machine. It is waiting for me to do just THAT with some old vhs tapes. Well, at least to burn the tapes to dvd. But I'll be from dvd to pc file is easy. I know there are conversion programs for that. I was successful a few years ago with 2 separate machines (vhs and a dvd recorder), converting tapes to dvd, for Carole Valentine. I'll try to experiment with my machine this week and if that works, you can always send me your tapes and I'll gladly convert them for you, if you don't find something local to help you.
Re: How is it done using two machines??
Stuart Johnson
How do you hook the two machines together? Don't the play and record channels need to be set somehow? I have a bunch of woodworking tapes (purchased) I would like to move over to dvd.
Thanks Guys, Looking into my MacBook Pro, it seems to have everything!
Oh I Remember
...when you helped her out, you are too kind!
Let me see how the Mac handles things, otherwise I might indulge you, the movies would be entertaining for you I am sure.
Take care,
Jim
Bill Howatt
You would take the composite video signal output from the VHS machine, usually the yellow jack, and feed it into yellow jack on the DVD recorder. The red and white stereo audio wires are likewise connected between the 2 machines. These are often referred to as AV (audio-visual) connections.
You would then play the VHS tape while the DVD was recording. Obviously, it is best to consult the manual for the DVD recorder. However, if the tapes are commercial they may have copy protection and you will find the recordings are of poor quality perhaps with funny colors.
If you have a combo VHS/DVD recorder machine these connections will be made internally when the appropriate mode is selected. The copy protection issue will still remain though.
Bill
I either did it as Bill explains or I connected both machines to the surround sound receiver/amp and went from one to the other. Hard to remember at this point, although, I think I did connect them together. They were not commercial tapes with copyright issues, so that was no problem. They were the vhs tapes of the shows I had taped for Carole, before I learned her vcr was dead and she had a dvd player. Curt Harms loaned me his dvd burner then. Now I have a combo machine that was my Dad's.
Re: Oh I Remember
No problem. You may need to buy some cables or a usb or firewire box to go between the vcr and mac, but it should work out (ooh, my least favorite words when dealing with computers!). Let me know if I can help you, my dear twin.
Jerry Samsen
I didn't read through all the posts and this may have been suggested. This is what I do. I have a digital camcorder as are most nowadays. Almost all of these digital camcorders can be set to convert an in-coming analog video / audio to a digital stream and then sent to your PC via Firewire also known as a 1394 connection.
Find an old VCR and connect the VCR video, L, and R audio to the digital camcorder. Connect the camcorder to the computer via Firewire. You may have to set the camcorder to enable analog to digital output through a menu. Fire up your video editing package (they all do video capture via firewire). Press Play on your VCR and start capturing the video in your PC.
I've done this with an old VHS collection. Then I did a little editing and burned DVDs. Don't expect DVD quality as the source is VHS. Blown up on a 60" TV may not look very good but does find on a PC display.
