Glue question
Glue question
Glue question
Joanne in Point Pleasant, PA
I am making some painted frames (a huge rarity for moi to use anything other than a clear finish on wood!) as baby gifts. I have some little wooden letters to paint and glue on the frames. Will regular wood glue (like Tightbond I or II) adhere to latex paint? Or should I use something like epoxy? What about painting the backs of the letters--then I'd have latex paint on latex paint--will glue hold paint to paint? TIA for your wisdom; I don't see latex paint listed on "thistothat.com".
Re: Glue question
Re: Glue question
George Colonel's Workshop-Havertown PA
Good Evening Joanne,
I would paint the letters before gluing them on the board. Once they are dry, I'd mask them carefully with tape, trim the tape to the shape of the letters, leaving the backs of ther letters unfinished. Then glue the taped latters to the board. Then finish the board and remove the tape. An artist's brush will take care of any voids.
I wouldn't try to glue latex finishes together. I'd use spray paint.
George
Re: Glue question
Re: Glue question
Hmmm. Good ideas, although, the letters are pretty small to mask easily. And since these are baby gifts, I wanted pastel colors and looked for but couldn't find pastel spray paints last week. Home Depot had little sample bottles of all sorts of colors and I was able to get all kinds of pastels in small quantities. I suppose I can try to place the letters on the frames, trace them and remove them, and not paint those areas, so I can glue bare wood to bare wood. Same end result. Thanks. You're brilliant.
Re: Glue question
Re: Glue question
Steve Schoene
If you have small letters on items that may end up near babies, then you want to make sure they are well glued so they can't come loose when baby chews on them. That means gluing bare wood to bare wood with the grain running the same directions. Paint or any finish on the glue surface significantly reduces bond strength.
Re: Glue question
Re: Glue question
These frames will be hung on a wall, so they shouldn't be near babies. Although, I do want the glue to hold well anyway. The pieces would not be safe near a baby if someone else knocked them off the frames.
Re: Glue question
When in doubt....test
Bill Tindall
I suspect that craft glue (white PVA) will glue the latex letters to the latex frame just fine. What is the force trying to render the letters from the frame.....gravity. It is not like you need the bond strength of gluing up wood panels and the like.
So, give it a test. Stick a painted letter to a painted frame and see what it takes to pull it off. My prediction is that the letter will stick adequately.
It can take days for latex paint to dry thoroughly. So, don't try to do the sticken until the paint is dry. If it smells, then it still has the coalescing solvent present and the paint will be soft.
Re: Glue question
Re: Glue question
Chuck Lenz
Is there a possibility that you can fasten the letters with glue and brad nails ?
Re: Glue question
Re: Glue question
Gerald Gibbs
I would use silicone.
Re: Glue question
Re: When in doubt....test
I'm with Bill on this. My gut reaction is that either white or yellow glue will stick latex to latex strongly enough that the paint will fail and not the glue. But, I don't know how strong latex is in this sense. And Bill is right, it might take a week or longer for the latex to reach even ninety percent of its final strength.
Could you glue on the letters on bare wood, paint the whole thing the background color and then just paint the faces of the letters? You might be able to roll the color onto the face. Nothing says fine hand craftsmanship like a roller.
Re: Glue question
Moses Yoder
Re:Silicone or Construction Adhesive
Moses Yoder
So long as you are careful applying silicone or construction adhesive to the back of the letters so it doesn't squeeze out too much it will work good. The backs of the letters could be painted or unpainted. Clear silicone caulk might work best because you wouldn't notice the squeeze out. Silicone really sticks good; you can easily glue wood to glass with silicone.
Re: Glue question
John E in SC
I would agree with Bill on this also. I think white Elmer's glue or Tacky glue would work fine for the intended purpose. This isn't a play toy - it will be hanging on a wall out of reach, so the force trying to "detach" the letters will be minimal. I'm sure wood-to-wood would be a better bond than paint-to-paint, but 14X overkill is still overkill. For the amount of extra time it would take to mask the letters or paint around them, I wouldn't do it. Just my 2 cents.
John
Re: Glue question
Re: Glue question
Thanks all. I had planned to do some test pieces anyway. Guess I'll paint some test pieces and let them all dry out and play with glue on those and bare wood. I suspect Bill is right and the wood glue will hold the painted surfaces just fine for a frame that hangs on a wall. Sure would be easier to just paint everything, let it all dry and then glue, and not worry about masking anything. I'll report back and post pics when I'm done.
Re: Glue question
Re: Glue question
FredD
If it were me and the letters are small , I would place the letters on a strip of masking tape , on the sticky side . Spray or paint the letters however you wish, let dry and paint the Backboard and let dry for a couple of days or more depending on the paint.
While the paint is drying , go to a craft store and get a Glue Stick.
If you haven't used one and I bet you have , that would be all of the sticking power you need and no mess with runny glue or squeeze out.
Like the others suggest , test it , I bet you the letter would be ruined before the glue let's go.
FredD
Re: Glue question
Another idea....
I use a Glue Stick to stick my business card into the front of my reports. Never thought of it to glue wood, I will have to try that. It really sticks paper through.
How about using double stick tape? Peal one side of it and arrange the letters on it. Paint the letters and then with something like an exacto knife, neatly cut the letters out of the tape, leaving it on the bottom of the letter. Peal the backing off the tape and place it. If you set them down very lightly you can move them around a bit. When you get them where you want them, press then down firmly. Probably more tedious than gluing them, what with trimming the tape and it would cost more than glue if you had to buy a roll of DS tape. Hmm, more tedious and more expensive, go for it.
