Band saw resawing blade
Gary Smyth
Delta 14" band saw. Has 1/2" blade installed. Oak, full 1" boards which I want to get to 3/8 or even 7/16" after resaw. Timberwolf mentioned that a 3/4" blade will work. Delta recommends only 1/2" wide owing to a 3/4 horse motor. Anyone have experience (or recommend) putting a wider blade on the 14"er? Also. Cranking down the knob to get greater tension to eliminate the bowing. I'm told not to do it owing to tracking error and tire damage --the blade will handle it. The books I'm reading don't indicate much other than to not do it too much. I'm running only 20 feet using a new blade. What should I be aware of, if anything, running these? I have a perpendicular tall fence which I can adjust for drift. Boards are 6" tall. I'm thinking this is straightforward work, but it's been a while since I resawed.
Re: Band saw resawing blade
George Colonel's Workshop-Havertown PA
Good Afternoon Gary,
My Jet 14" saw has a slightly more powerful motor, and I have a 3/4" Timberwolf blade. I much prefer the 1/2" resaw, and I regularly use Timberwolf and Wood Slicer versions. I believe the 1/2" blade is slightly thinner, and cuts smoother. I believe your saw has sufficient power for the job. I'd expect no problems at all with the 3/8 inch planks. Two nominal 7/8" planks may also be usable if only the face sides are shown in the final product.
George
1/2" for me
Hoa in Alameda
I tested Timberwolf 1/2" and 3/4" blades. No contest, the 1/2" blade produced better result. The board was 11" wide hard maple.
I've never bought blades wider than 1/2" since then.
My saw is an old 14" metal/wood cutting Delta with riser block and an Iturra spring. The saw motor is 9A/240V.
Lee Schierer McKean, PA
I use a 1/2" 3 TPI blade for resawing. I don't believe a 14" saw will properly tension a 3/4" blade with a factory spring. If the folks at Suffolk Machine say use a 3/4" blade ask them if they will exchange it if it doesn't tension properly on your saw.
Lee
Re: 1/2" for me
paul in AZ
I have a Jet 18" and ran a 1/2 inch Timberwolf blade seemingly forever and was very happy. It finally began showing signs of dullness so I put on a 3/4" 3tpi [also TW] which I bought back when I got the saw. It 'thumps' which I don't think they're supposed to, wanders a little and the cuts are MUCH rougher. I simply don't like it and will be getting another 1/2" soon.
To quote a recent message I got from Highland Woodworking...
"The Wood Slicer blade excels at resawing kiln-dried North American hardwoods and softwoods. It has a very minimal tooth set so the kerf is small, keeping waste to a minimum. It leaves a nice surface finish than more aggressive cutting blades that can also work for resawing.
We've only sold the 3/4" wide Wood Slicer for the past few years. The 1/2" Wood Slicer has been the blade our customers have used quite happily for close to 20 years. The 3/4" band became available and we offer it as a choice to our customers with larger capacity saws who kept requesting a wider Wood Slicer band for their machines. The 1/2" & 3/4" bands are identical in every respect except for width.
Our tests on a Delta 14" saw with a riser kit showed that the 3/4" Wood Slicer performed exactly the same as the 1/2" wide Wood Slicer. You can spend more money on the wider Wood Slicer, but you may find the 1/2" works just as well as the 3/4". ..For those who haven't yet purchased a Wood Slicer, you may want to start with the 1/2" width band (hey, it costs less) and once dull, splurge on the 3/4" and note if the extra cost translates into a worthwhile increase in cutting performance on your saw.
The majority of our customers have 14" diameter consumer grade saws (or smaller). While some of these saws can mount a 3/4" wide band, that width somewhat pushes the envelope of capacity for those saws (in our opinion). For larger capacity saws this is not the case, though running a wider blade (of any ilk) does not automatically mean your saw will cut better when resawing. Blade width cannot make up for a poor tuned saw or an unsuitable blade tooth configuration for the cutting task. "
Larry in NW OHIO
I have an old, something like 30 years +, 12" Craftsman with a 1/2 HP motor and a 1/2"woodslicer blade. It cuts 6" oak very well. no drift, hardly any cut marks. I highly recomend the woodslicer blade, if it cuts this well on an old sears, it`ll cut on anything. Larry
ron
I don't bandsaw regularly & of course resaw even less. Recently put Highland's 3/4" woodslicer on my Delta 14" (1.5hp?). Seemed like an upgrade from 1/2" to me. I was ripping 4" ash. I wouldn't call the result smooth, but I wasn't trying either. It's nice having a blade that isn't going to be fussy and wander.
Mark Duginske
The problem with most 3/4" inch blades used on a 14" band saw is the blade thickness.
Most manufacturers make the 3/4" blade of thicker material which metal fatigues when
it has to bend around 14" wheels. The blade often fatigues and fails with multiple small
cracks. On some saws it is also a problem to position the blade on the wheels.
1/2 all the way
Scott Burr in Ben Lomond CA
There's no reason to run that wide of a blade on a small band saw. That said I like wood slicers better than timberwolfs myself.
Scott, with a 14" delta w/riser, irua(sp) spring and ball bearing guides.
Does all I expect it to, maybe sometimes more :)
!/2" blade   check blade drift ??
del schisler
Guides?
Tony - Memphis
So, how do you like the roller guides? I've been considering those. The cool blocks are fine, but they don't fit the sqaure holes well and they slide all over the place when I'm adjusting. I glued some veneer to the sides to make a snugger fit and that helped. I just figured the rollers would be easy to adjust since it wouldn't matter if the moved up or down a bit.
Tony (14" Jet with riser block)
Ever Try White Oak?
Good Afternoon Tony,
Some time ago I read about white oak as guides in lieu of cool blocks and original equipment material. I cut myself some white oak, and have used the same 2 "sticks" for 10 years or more. They can be dressed square easily on a disc sander.
Also, you can't beat the price.
George
Hi Tony...
I switched to these from the cool blocks for the reasons you stated.
I think their great for the price compared to other companies. I've had them for a few years now, and I'm very satisfied with them.
Thanks!
Tony - Memphis
Re: Ever Try White Oak?
Tony - Memphis
I may try that. I do recall using a bandsaw in a class that had wooden guides. I could certainly make them fit that way. I'll have to find a stick of white oak. I have a couple of small pieces of red somewhere.
Tony
Jim DeLaney, Austintown, Ohio
Tony,
A lot of different woods work well. Lignum Vitae is probably best, but also the hardest to find. Maple works very well, too, and I'm sure that many of the harder exotics would work.
Probably the easiest way to get a small piece for bandsaw guides - assuming you don't already have something suitable in your scrap bin - is to buy a pen blank. They're relatively cheap, and contain enough wood to make a full set of guides.
Tony - Memphis
Great idea. Thanks. I do have some cocobolo around. That stuff is pretty dense and polishes up without any finish. As an engineer/geek type, I'm interested in the rollers, but I may play with some wood just for kicks. I've been lucky with my Jet BS in that I've never fussed with it and had pretty good results for what I've used it for. I'd like to do some precision resawing (like making veneers) and I'm not sure how that will come out. I need to try it out and see. I've done lots of resawing, but usually its real thick stock into two pieces of less thick stock. I am building some chairs out of makore and I had to resaw some of the 6/4 stock to make the arms. I didn't want to waste the leftover so I resawed it off and it actually came out pretty good. Not sure what I'll do with the leftovers, but it's nice stock for a small box or something like that maybe. I got soem beautiful beeswing makore veneer on an eBay deal that I may use with those pieces to make some small boxes....someday!
Tony
