Re: System Three Clear Coat Epoxy
The bubbles are (usually) from the mixing, even using a gentle stir. You can deal with the problem is several ways.
One, you can thin the resin with some denatured alcohol (not more that 15% by volume) to reduce the surface tension of the liquid and make it easier for the bobbles to migrate to the top and "pop".
Second, you can pass a gentle flame (or heat gun) at a low angle over the wet surface to slightly warm it. This will draw the bubbles to the top and make them open.
Third, moving slowly, you can "spear" the bubbles with a tooth pick.
Lastly, if you're set up for it, after you mix the resin, cap the container and hook up a vacuum pump. A few minutes of high vacuum will draw most all of the bubbles out of the mix, then pour the resin onto the surface and tilt, do not brush, to spread it. Alternative on the vacuum is to put the coated item in a vacuum chamber, but I rather doubt you've got one of those kicking around the shop.
