Malfunctioning remote for dust collector..
I have an Oneida Super Dust Gorilla (220 V) with a remote.
The "On" button for the remote isn't working. The "Off" button still works.
Oneida wants ~$77.28 for a new remote (at least that is what their website says). I would have to add shipping to that. I can get a new wireless system at Woodcraft for $72.50.
So - any other alternatives? I've opened the unit, removed the battery and blown it out. I've also wiggled the "On" button. As I said, the "Off" button still works and will turn my SDG off. It would be nice to have a working remote - just not ~$70 nice.
Re: Malfunctioning remote for dust collector..
Get some contact cleaner and spray the on switch real good. It might not help but is a cheap fix if it does. My cheapy unit is starting to do the same thing but it's probably 7 years old.
Larry in NW OHIO
JL Definetly try the contact cleaner, it does wonders , sometimes. Also try new batteries and clean the battery contacts. I have an at least 12 year old remote I got at a Furrow lumber that was for turning on a light, this was before they came out with remotes for DC. I rigged it up to turn on my first junk DC I bought. Best of Luck Larry
I tried. It didn't work. The switch is small and on a circuit board (sort of a "square"). The battery works fine and seems to have a reasonable charge. It also manages to turn off the DC.
Sigh - I've got a newer price of $35 for just a remote. More reasonable but still - $35 + shipping for a key chain remote??
those are momentary switch actavated
del schisler
those are momentary switch. If you have the pc board out look on the bottom and see if their are 2 little pin's that stick below the little switch. If so take a jumper and short those out. If nothing happen's that a part must be bad on the pc board. Been in repair for 50 yrs on this stuff. Now if it start's up than the switch is not making inside. That about as far as you can go. Part's would be hard to fine. These are mfg. to a certian speck's and part's. Most of this stuff is a thro away item's. That's what wrong with the usa. thro away and make a new one. Of course over sea's get the money.
