crotchity contractor saw
Joe Shelton
Can't seem to get the blade height adjustment to work smoothly on my saw, which is a Ridgid model that had previously been sold as a Craftsman.
So far, I've just tried to clean the screws and mating parts with sprays (WD40 and a lithium grease). I haven't inverted it and taken it apart any. The hgt mechanism creaks and strains surprisingly badly, and no blade I put in it cuts as well as was the case before.
How do I evaluate the machine, to decide whether it's still serviceable?
Thanks
Joe
Re: crotchity contractor saw
I'm not familiar with that particular saw; but if you're confident that the moving parts are clean and lubricated, the next most likely problem is something got bent. I don't know if that would work as well upside down as right side up (Delta contractor's saws, for instance, won't work upside down because the motor mount depends on gravity). If it will, I'd flip it over and see if there's anything visibly bent.
As Bill suggested, something may be bent. If you can have someone else try to work your height adjustment while you watch, that may help you diagnose the exact problem. If it is bent or binding, you can usually see this.
Before you do this, might I suggest taking a brush (brass bristled or paint stripping brush) and scrubbing your screws clean. I will (upon occasion), dip a brush in a jar of kerosene or mineral spirits and scrub the ways, screws and other mechanisms of my table saw. I've been surprised at how much gunk accumulates. This will allow you to evaluate the mechanism a lot easier.
Re: crotchety contractor saw
Not familiar with that saw. I have an old Rockwell Delta version.
Two thoughts. I would clean as JL suggested and then apply some sort of Dry lube. Lithium grease will work long enough to tell you its working well and not binding, but may quickly accumulate crud again. WD40 works as a cleaner, but is not much of a lubricant and I have no idea if the combination works well together or they destroy each other. Graphite and Slip Plate are two dry lubes I can think of. There are other's.
The other thing I wonder about is how this affects the quality of the cut. Once the blade is in position how does how it got there affect the cut? The squeaking and scraping would have nothing to do with the cut. OTOH, if the arbor bearings have gone bad, that would not cause squeaking and scraping while adjusting the blade.
So, Once the blade is in position, is it firm and secure? Has something come loose or failed allowing the blade to wobble or vibrate?
Just an idea
Lee Schierer McKean, PA
My contractors saw has a plastic shroud over the belt and motor pulley at the back of the saw. Before I made my out feed table pieces of wood would sometimes drop and hit the plastic guard changing its angle slightly. Then when I would try to raise the blade the plastic would hit the frame of the saw and creak and groan, making it hare to raise the blade. YMMV.
Lee
Clint Searl
It's just dirty
Clint Searl
I had the same problem with my Delta 34-444.
Flip it over and give it a good cleaning.
Clint
I agree with Clint plus
Bruce, a MN Galoot
when you clean out the gears, etc., don't use a lithium grease. It only attracts sawdust and will mung up with works. Use a dry lubricant like spray Teflon or graphite.
It seems that I have to take my old Delta contractor saw apart about every other year. It's not that big a deal, just takes time.
Get Rid of The WD-40
While it's a reasonable penetrator and better cleaner, it's not a lubricatant and dries to a sticky film that will gum things up.
Only thing I put on elevation/tilt threads is dry graphite lube.
Re: Get Rid of The WD-40
Ditto what Mark says. Everyone uses WD-40 for everything and it's really only good for one thing. Dispersing water. It does function pretty well for protecting surfaces like lathe beds.
I think your best bet would be to clean it with Mineral Spirits and a good brush. Then apply a dry lubricant. When I last did my Powermatic I used white lithium grease. Applied it and then wiped it off. That's worked for quite a while.
Ditto Dry Graphite Lube
Gary Hodgin
Chuck Lenz
I don't think that you give enough information about which saw you have to give an accurate diagnosis, but this is my best guess. Either the handwheel lock is not disengaged, or ( this is my best guess ) on the belt cover side of the motor NOTE: Do not attempt to tighten the pivot screw as it must move freely in the slot as the blade is raised or lowered.
Chuck Lenz
The only reason I came back is because someone called a Contractor's saw a degradeing name, and it really bothers me when people do that. I get tired of being bullied into thinking that I have to have a cabinet table saw to be a good woodworker, or to fit in with the crowd.
