WE MOVED...
REAL MILK PAINT
How to roast chili peppers?
Bill Tindall
Sunday the local flea market (that never has any useful hand tools) had a Mexican vendor with some choice Pablano peppers. I love Chili Rellenoes but to get from peppers to Rellenaoes the hide needs to get burned off. If Mexicans were as awkward at removing chili hides as I am they would all be skinny, or at least Chili Rellenoes wouldn't be a national dish. Does anyone have a convenient means of roasting chilies?
Re: How to roast chili peppers?
Chuck Kettler--Greenwood, IN
I use a propane torch. Or if you have a big bunch use your BBQ. Put them in a paper bag after heating and let them cool and then they are easy to peel.
I'm Usually The One Who Is Roasted, Bill
George Colonel's Workshop-Havertown PA
But I love 'em.
George
steve mackay
Well, if you've got a couple it can be done on a gas stove top or other burner. Never done it but I figure a propane torch with the fan / spreader atatchment would do it. The grocery stores here have large rotating baskets / barrels (think bingo or lottery) with BIG propane burners underneath. The barrel / basket rotates with a motor. Has to be done FAST though or the meat turns to mush.
Personaly, any dish I make only needs a couple and the stove top does fine and with more control.
Steve, with chilies and peppers in all his "flower" beds.
(Quote "The Great Escape" : You can't eat flowers.)
Leon
I roast them on the grill and then put them in ice water to stop the cooking. Then skin them and put a slit in them to get out the seeds and put in the cheese.
I have done some inside on an electric range but have GOOD venting and wear gloves while peeling!
YMH&OS
Leon
Jim in Burlington Ont.
Charcoal
I prefer to put them right on the coals and quickly char the skins then put them on a rack to cool. Red peppers can be put in a bowl and steam them after roasting to help the skins fall off. Personally I freeze them after the skin is off so yoiu can have them in the middle of winter.
About stuffing...
John in NM
A friend of mine puts cooked potato in with the cheese, maybe half and half or so. Gives the relleno a bit more body. I never asked how she skinned them, too busy eating :D
wilbur
We have a gas stove/oven. We either lay the chilies directly on the gas flame on the stove, or crank the broiler in the oven and put them underneath the broiler flame in a cast iron pan. Either way, dunking the charred chilies into a bowl of cold water really helps the skins to come off.
Here is the problem I am having
bill tindall
I can burn the crap out of the skin, like turn black, with a torch (actually a Meeker burner) and the skin comes off in tiny stick- to- everything pieces. But, any place the pepper is concave the skin doesn't burn and it won't come off. If I don't char the skin black over the burner the skin doesn't release at all.
I see pictures where the chef is peeling what appears to be a translucent skin and it comes off in large pieces. The skin appears to be totally released from the pepper and the pepper seems more cooked and soft than I get burning them with a torch.
So my problem seems to be with the proper amount or duration of heating. How long and what should I be looking for to know they are ready for peeling?
Clint Searl
MAPP torch
Clint Searl
I char mine with a MAPP torch, and throw them into a big covered pot so they steam themselves till the skins can be rubbed off easily. Good for all types of fresh peppers.
Clint
Jesse Cloud
The flatter the chile, the better for roasting and peeling. I roast mine over a gas flame. The 'valleys' will need to be almost directly over the flame. Take your time, the entire chile should wind up black and wrinkled.
I then place the chiles in a large bowl with a towel on top and wait 20 minutes. The skin comes off easily.
One of my favorite dishes uses roasted poblanos. Sear some cubes of pork or chicken over a high flame with a little oil. Remove the meat and place on a plate to rest. Toss in some chopped onion, brown, add chopped tomatoes, the poblanos, come beef or chicken broth, and salt and pepper. Cook until the sauce reduces. Add the meat and cook until warm or done to your taste. Sprinkle with some cilantro.
Yummm!
Here in NM, we buy 30 pound bags of green hot chiles and have them roasted. Freeze them for the rest of the year. Just now, the sweet fragrance of roasting chiles is everywher.
However you do it, a warning...
... hot pepper fumes can kill parakeets and presumably other caged household birds.
Jason Roehl in Lafayette, IN
I didn't know what warning to expect...
...in your post, but of all the possible ones out there, THAT one did not cross my mind!
It's an interesting bit of trivia, nonetheless. (Though I'm sure it's not trivial to those who discovered it in a tragic fashion).
Jason
Patience
wilbur
On the stovetop, it takes me about 10 minutes to blacken the skin off of a red pepper, and I rotate it to get all sides. It's about the same under the broiler. If you're not getting the concave sections blackened, you're just not letting it go long enough.
The time factor isn't a big deal to me. Then again, I'm the guy that resaws with a bandsaw with a 1/2 HP motor. ;)
Speaking of which, I resawed a 6-1/2" wide piece of white oak last night, using that 1/2 HP motor. Again, the saw didn't seem to bog down, and this time I was using a 3/4" 3 TPI blade. I think the blade is a bit dull, but it worked great.
Robin Corell in Atascadero CA
If you take the chilies directly from the flame and place them in a plastic bag the steam will sweat the skins. Then dump the plastic bag on to a towel,fold it over and roll them around to dislodge the skins. slow is better than fast and I have better luck on a charcol grill.
Robin
Wasn't that the name of a band?
Lee Schierer McKean, PA
Hahaha, Lee.
That would be the "Red Hot Chili Peppers", one of whose members was named, "Flea".
I used to listen to them--20 years ago. (Dang I feel old now--starting to sound like my parents).
Jason
time question
bill tindall
How long does the "grilling" take? Or, if anyone has seen it done in a store how long are they roasted before skinning?
I think I may need less temperature and more time to get the translucent skin that peels in big strips.
clay foster
Bill,
A convenient way is to burn the skin with a propane torch until it turns black and blistered but not all the way to ashes. Do the best you can getting down into the valleys, but don't sweat getting every little bit burnt. Putting the chile in a plastic bag will do the sweating for you. When the chiles are cool, the skin will slide right off in big pieces. Any small unburnt bits you can't scrape offf with a dull knife aren't going to affect the rellenos. Steaming in the bag also cooks the chiles a little more. If they still aren't soft as you want, micro wave the chiles to whatever doneness you want. Personally I like them to be a little bit firm.
For maximum flavor, and if you have a bunch of chiles you want to roast and freeze, roasting them over a real wood coals is my preferred method. Pecan/hickory makes nice hot coals, but mesquite is hotter. I have a grill/smoker I use for this. Get the grate right down over the coals. When the skins are burnt and blistered, put the chiles in a plastic bag to sweat. When they are cool, spread them on a cookie sheet and put them in the freezer. Don't peel them. After they are frozen, put them in big plastic freezer bags. When you need some chiles later, just take out what you need and let them thaw. The skins will slip off almost whole when they have thawed. I roast and freeze about 40 pounds of Hatch green chiles every year this way.
But today the Black Dragon is smoking a pork butt.
Re: time question
wilbur
As I mentioned above, either the gas burner on the stovetop or the broiler method that I use takes about 10 minutes total for a pepper. I mainly fire roast red bell peppers or jalapenos. You do have to rotate the pepper as well during the process.
Error of my ways revealed
Bill Tindall
I have been trying to pyrolyze the skin as quickly as possible so as to NOT cook the pepper meat. It seems from the directions you all have provided that my approach was flawed, leading to intractable skin and still firm pepper meat.
I have a second batch of plump Pablanos which I will do slowly over the coals or under broiler.
Much thanks to all
