Cherry in the Sun
Cherry in the Sun
Alan Young
Cherry in the Sun
Alan Young
The Col. and others here have made mention of placing cherry in the sun to age it quickly-. Is this method dependent on temperatures or just time? Does the time of year affect the process? ie- angle of the sun etc....
-Alan
Re: Cherry in the Sun
Re: Cherry in the Sun - guessing
Henry (Raleigh, NC)
Alan: While there may be a temperature effect, I doubt it is significant. I expect this is primarily a UV photochemical effect and so I think of it as having a "sun tan" effect like on your skin
I would guess that the most significant factor is the light intensity; time of day and time of year are important considerations.
While you can't do much about time of year, but you might have choice about what time of day you sun tan your boards (think noon-2 PM).
Henry
I did it once but I didn't want the wood to get too dark. So I slathered Coppertone SPF 30 all over the wood. Turned out to be a huge mistake. On the plus side, it smelled like Hawaii after that.
T.
George Colonel's Workshop-Havertown PA
Good Morning Allan,
I believe exposure time is more important than season. I set out pieces mostly in the Spring, Summer, and Fall. Winter's days are too short. When I do it, I get the pieces out relatively early in the morning, periodically adjust their position for equal sunlight exposure, and get them back inside or on the screened in back porch around sunset. How many days? I'd say around three minimum in strong sunlight, especially if I need to scuff back perceptable grain raising. Most of the time, grain raising isn't significant.
I normally give the entire piece a spit coat of shellac, scuff and tack, them apply a 50/50 mix of naptha and poly, rubbing out every two or three coats. I like shellac, although some assert it is unnecessary under poly. Maybe so, but I like it anyway.
George
:D :D :D
George
Dave Bair, Eaton Rapids, MI
I've always sunned my pieces after I've applied the final finish. I usually sun them over a period of 2 days changing the side facing the sun every half-day. I also like to sun the bottom of things, like benches, that may be seen from an angle.
paul in AZ
With cherry I usually wipe on a coat or two of boiled linseed on it just before or during the sunning process. BLO accelerates the color change and pops grain. A simple wipe on/wipe completely dry and wait a day or two before repeating. The duration of 'tanning' varies from a couple to maybe 4 days in our intense sunlight. That mostly depends on my impatience. I'd have to guess that this gives me the equivalent of a year or two of color change sitting indoors.
From there I give it a few days rest if the finish is to be poly.
Alan Young
Thanks for the comments
Alan Young
I think I am running out of time for this process on the project I have going. Looks like I'll need to just let aging happen naturally-The weather here is too wet and by the the time it drys and the sun comes back I'll want/need to be further along. Still this is helpful for another project.
Oh and Tom-just keep your pants up!
Re: Thanks for the comments
I'm not that cute. T.
paul in AZ
If time is pressing and weather isn't cooperating, just wipe on some BLO, let it sit for a few minutes and wipe it dry. One or two coats will pop the color and grain considerably without needing sunlight. It will accelerate the color maturation.
Not To Disagree
Good Evening Paul,
I've gotten good results with plain old lye as well as potassium dichromate. Interesting enough, the two on the same sample boards yielded slightly different color and shade. Whatever works well, works well.
George
Joanne in Point Pleasant, PA
Of course you are, Tommy!
Hey, if you're in a hurry, try that QT--Quick Tanning--lotion. Puts the color right on! Watch out for streaking and turning too orange. :-)
