Broken bandsaw blade guide assembly
Mitch from TN
Hello all,
I have a Craftsman bandsaw and the support (or whatever it's called) that holds the blade guides broke. I can't find a replacement part, so I'm asking for a couple of suggestions. 1. would it work to have someone weld it back together? or 2. can you suggest how a non-metal-worker could make a substitute out of wood? I don't want to be too fussy about it -- just want something that works and doesn't mess up the blade. I see that Carter makes high-end replacements, but my budget is not $169 but more like $6. :)
http://www.flickr.com/photos/10465474@N04/4994121683/
Thanks,
Mitch
Re: Broken bandsaw blade guide assembly
Fixing on the cheap
Virgil Johnson
Looks like it is cast alum. so brazing/welding is not an option. Here are a couple of suggestions. If a small flat head screw will fit in the slot I would try to screw the parts back together. Another option would be to use roll pins instead of screws. CA glue or JB weld might hold the halves together while you are drilling for roll pins or drilling the tap drill size for a machine screw. If you use the screw method drill the tap drill while the halves are assembled, break apart then open up the clearance side.
Re: Fixing on the cheap
Larry in NW OHIO
You didn`t say what modelyou have, but I have an old one and mine are made form aluminum and They broke also and I was able to screw them back together. Also I bought some used ones from EBAY. I think just a week ago they had another set for sale, so you might try there. Look under "Craftsman bandsaw". Good luck Larry
PC-7
Lee Schierer McKean, PA
Get some PC-7 two part epoxy. It will mix up as a thick putty. Put it on the parts in the area that is broken and build up that area with extra thickness. Once the putty is put in place you can smooth it with a wet finger and even feather the edges. It takes 24 hours to set up but it is incredibly strong and it fits your budget at about $9.00 for a small set of cans at Amazon. Just make sure the joint stays aligned as you want it while the epoxy sets up as it is difficult to remove.
Lee
