(LBL) Laminated Bamboo Lumber info?
David Barnett
David Barnett
I need a source for LBL engineered boards -- not flooring or plywood or anything with bamboo veneer over other substrates -- and hopefully, in small quantities, if such a thing exists, for a few one-off furniture projects. Woodfinder returned 7 hits for bamboo, but not what I was looking for, and Google has so far only returned bulk foreign exporters.
What I'd really like is board stock up to 6/4, but don't even know if such a product has hit the market. I've seen engineered bamboo beams in trade videos and lumber in a promo brochure with a dead contact URL.
Is anyone on WC using these products to build furniture? Any ideas?
Re: (LBL) Laminated Bamboo Lumber info?
Alexandre Grigoriev
I saw 4/4 sold at local Rockler. Was expensive.
Howard
There is a product called Plybo distributed by a company on the West Coast. That's all I remember.
David Barnett
David Barnett
Thanks, but I didn't find it online. Will call later, though, in case they have some in stock.
David Barnett
That would likely be Smith & Fong 'Plyboo'...
David Barnett
...which does indeed come in edge-up laminated flooring, which I have used, but it's only available in 5/8" or 3/4", and in standard flooring widths. Incredible range of products, though. I'm a big fan of their end-grain Durapalm plywood, but can't afford it, heh. Thanks.
Kevin Stanbary in McHenry, IL
I did a quick search out of curiosity and found this:
http://www.calibamboo.com/bamboo-lumber-lumboo.html
David Barnett
Thanks, Kevin
David Barnett
Compressed bamboo fiber lumber is an interesting alternative wood product, but what I need is similar to edge-oriented solid bamboo lam flooring. The samples I've seen of Lumboo� is fairly coarse looking on the surface and doesn't lend itself to exposed end grain in furniture. Closer though. Again, thanks.
Sizing
So the lumber is way smaller in dimensions than the "nominal" sizes they list - and they even acknowledge it - but they can't just list the true size up front?
Bad enough that nominal 1" redwood and cedar are down to 11/16" and even 5/8" in this area, but to sell something 1/2" thick as a nominal 1" board seems like it's going a bit far.
Bill, just barely old enough to remember nominal 1" lumber that was 7/8" thick.
