Ceramic Bandsaw Thrust Bearings
George Colonel's Workshop-Havertown PA
Good Afternoon Friends,
I had to change out my blade and discovered the lower thrust bearing had frozen. Since the retaining screw was also frozen, I made a quick trip to #3 son's shop and used his(my former) 14" Jet. Today, I successfully removed the thrust bearing retainer screw and decided to install a "Spaceage" ceamic thrust bearing I had purchased from Klingspor several years ago, and never used. The package contained two washers, each of a different OD and ID , and two ceramic bearings. No instructions on how to install.
I suppose the washers are spacers to be used as needed. Is that correct? When the bearing is married to the shaft, and the retaining screw is in place, the bearing won't spin, as does the original equipment. Should the ceramic bearing spin? Should I install both ceramic bearings, as the upper one is fine?
Are these ceramic bearings any good? The package extolls their merit, but did you ever hear a vendor yell "Rotten Fish"?
Let me know what you think. I need to get the saw back in service. Thanks.
Re: Ceramic Bandsaw Thrust Bearings
Colonel, I can't actually answer your question (That's never stopped me before and won't this time either.), but my under standing is they do not spin. The are trust bearings in the sense that if you thrust on the blade it will bear on the surface and slid on it. They are very hard and slick and will not wear.
On a personal note, I just bought Carter Bearings for my 14" Delta. I have to say that so far I am underwhelmed. Perhaps I don't understand them, but so far they are very "fiddly". Requires two or more allen wrenches. You loosen various set screws and slid the bearing into position. Or at least try. You get them where you want them and the second you touch them with the allen wrench, Fuggedaboutit, they are somewhere else. Seems obvious to me they should have some sort of threaded shafts that could be dialed in and then locked. I got them and put a new blade of the saw and tiddled and twiddled and fiddled and finally started to use the saw. A few hours of saw time latter, I decided to change to a new blade to do some resawing and was astounded to discover the bottom set fell off when I removed the blade. Either a set screw backed out or I failed to tighten it. And it was on the back side so I had to remove the lower assembly to tighten it. I installed the new blade and cut one piece of heart pine about 12" long and the lower bearings are coated with pine pitch. I am becoming very skeptical that my money was well spent.
Larry in NW OHIO
Colonel I have a Craftsman bandsaw, for over 30years, and still running very well, it was one of the last ones to be made in the states. A few years ago I put ceramic holders or what ever a person would them. They are the things on the sides of the blade to hold the blade from going sideways. I never had to replace them and they do the job. I don1t think you would have to replace both unless you want to. The blade don`t really care what holds it in place just as long as something does. Larry
Jim DeLaney, Austintown, Ohio
I've had the ceramic thrust washers on my 14" saw for several years, and won't ever go back to ball bearings.
No, Colonel, they don't turn. Maybe after the first thousand board feet get cut you'll want to loosen them and rotate them a few degrees, but really, there's no wear noticeable on mine.
I originally got mine after using my Laguna 16" saw for a few years. The Laguna saws coms 'standard' with cerabic thrust discs - and ceramic guides, too. I liked them enough on the Laguna that converting the 14" saw was pretty much a no brainer. I do still use Lignum Vitae for the blade guides on the 14", though.
Re:Thanks Jim,
Good Evening Jim,
I'll put the saw back together tonight. I have been using white oak blocks as my saw guides, although I know lignam vitea is a better choice. Trouble is,I don't have too much of that stuff laying around the shop. I was much relieved when the frozen retainer screw finally gave way under a torch's heat. Funny thing, the bearing is still frozen despite the smoke pouring out of it, and the little oil fire which developed in the bearing ring.
I'm happy to note that the ceramic stuff works as advertised.
George.
You'll probably go round and round on this
before you get a final answer.
Re: You'll probably go round and round on this
Larry in NW OHIO
OK Now I understand I was talking about the wrong thing. But I like the guides anyway. But where do you get these thrust bearings, I looked around but can not SEE them, I may have found them but can not SEE them. Thanks Larry
cermic thrust bearing's *LINK*
del schisler
go here and pick out where you want to order and read about them.
http://www.google.com/search?hl=en&source=hp&q=cermic+thrust+berings&btnG=Google+Search&aq=f&aqi=m1&aql=&oq=&gs_rfai=C4ZmnDL6QTPa8KoGOzQSysODfAQAAAKoEBU_Q9stb
That's a great Colonel imitation, Bill!
wilbur
jcousins
i have ceramic guides & thrust bearing on a mm16 - the thrust bearing does not spin. like barry i also tried the carters but found them way too much fiddling to get set. the ceramic setup is the best so far - after "some time" i do loosen and rotate the thrust bearing a little just to keep the wear somewhat even. i got them from laguna. felt like it really tuned up the saw.
jerry
Thank ya...thank ya ver' mush...
If he asks the question, he can't riff on himself, after all.
