WC Weekend accomplishments......
Dennis E Peacock
13 Sep 2010
Good Morning Everyone,
I'm beginning to get a bit excited as the temps begin to cool off from the 100+ degree days to days in the 80's and that means that it's getting closer to time for me to work my schedule out so that I can get in the shop again. Yea!!
Been learning and doing leather work and helping my kids learn about leather work. My daughter has made several pieces to give away as gifts and she does pretty good at this stuff because she's more on the artsy/creative side of the line that the rest of us.
The LOML and I have been working on stripping my great grandmother's old rocking chair so that we can re-upholster it. So now I'm getting to learn about upholstery, leather craft, and how to keep sewing machines running all at the same time!!
Soon my daughter and I will be starting the work on her hope chest and I need to get my jointer knives sharpened up before I start that project. Time to warm up the old Tormek and put an edge on my knives and tools once again.
Well, that's it for me, so what did YOU do this past weekend??
Best of weeks to you all.
Dennis Peacock
Re: WC Weekend accomplishments......
John Veerkamp
Went to IndyFest at Ray's outside Anderson, In. It was 550 miles and a long trip but worth it. Finally met a lot of WC folks face to face and renewed a few others. Saw some great demo's and learned a lot. Came home fired up to try some new things.
Re: Painting
David Hay Denver
Spent most of the weekend working on the workshop instead of inside it. The shop is woefully due for a new coat of paint (plus, who ever thought orange would be a good color for a shop?) So I spent most of Saturday afternoon finishing the first coat of paint.
I did get a little time on Sunday to work on a couple of small projects. Added a coat of finish to an end grain cutting board I recently completed.
David
Shop enhancement
Rod Peterson�Ormond Beach, FL
Aside from the 240V remote DC switch I installed a couple of months ago (on which I may or may not have reported), not much has gone on in my shop for a while. Until, possibly as an avoidance project against the bookcases SWMBO has been nagging me for, I finally got around to piping my shop for air.
In the Illinois shop, I had run galvanized pipe to three filter/regulators, plus a line out to the garage to another filter/regulator. That way I was able to keep the compressor at a location which was convenient (and quiet) yet still have air where I needed it. I had found, for example, that air in the garage was important for bicycle tires and air tools for the car, but compressor motors don�t crank well at -10°. Also, I theorized that the pipe itself serves as something of a manifold, thus providing more reserve air for those demanding sanding jobs I anticipated. Well, never mind all of that, in Florida I was tired of having a long hose permanently laying on the shop floor and wanted to be able to more easily vary the pressure (the brad nailer uses less pressure than the bicycle tires, for example).
Say hello to copper! I used copper this time mostly because in Illinois I had access to a Ridgid threading set. Also, I had perfected my copper sweating skills earlier in the remodel, which is reflected in the fact that I�m only losing a little bit of air, and that almost certainly in one of the regulators (not my fault). And how I wish I had bought my copper pipe about four years ago before the price spiked. Anyway, here are some shots of the result:
east wall manifold and pipe
The location of the compressor (out of view below the tool chest) and the principal manifold on the east wall.
detail of main manifold
Closeup of the principal manifold. Shut off valve isolates the system from the compressor (attached by �whip�).
second regulator/filter at west end of shop
Detail of the secondary manifold on the west wall.
main trunk near compressor
The main trunk line goes up in the south east corner…
line along ceiling of shop�note pitch
…across the length of the shop (note the 1" in 4' pitch)…
trunk and drop at west end of shop
…and drops down to the west regulator/filter.
I pitched the pipe because compressed air is naturally wet, and any condensate that develops will be able to flow to the far end. You'll note the drain fittings at either end of the system near the regulators.
The additional pipe works out to ≈ ½ gallon extra capacity, which isn�t much in the grand scheme of things, but given that it�s ¾" should permit pretty good flow on the west end, >30" from the compressor. That�ll accommodate my spraying, although I don�t know how much sanding I�ll do there. The big deal is being able to easily reach car tires—especially without having to stumble over a hose reaching all the way back to the compressor—and being able to regulate pressure out at the drop, also without having to go all the way back to the compressor.
Rod
Re: Shop enhancement
Dick Coers
Looks great! That far side run should definitely be the one used for spraying. The hot air from the compressor doesn't like to give up it's water until it cools. That filter right next to the compressor won't seperate out much moisture. The copper will sure help with the air cooling. Beautiful!
Jim DeLaney, Austintown, Ohio
Re: WC Weekend - Mostly on the couch
Had gall bladder removal and umbilical hernia repair surgeries on Friday, so spent most of the weekend in the LazyBoy with my new friend VICodin.
Surgery was at 7:30, and almost unbelievably, I was home by 1:30! One hurtin puppy, but home...
Doctor said the hernia repair would be way more hurtful than the gall bladder removal. He was definitely right!
Anyway, off the Vicodin yesterday, and onto Tylenol. Feeling fairly good today, and up and about. Followup next week, then all back to 'normal', I guess.
Larry in NW OHIO
Rod Great looking shop enhancment, that will help a great deal. Jim best of luck on recovering, my Sister-in-law had hers out just last Monday and she feels a little rough yet. It`s not good whenever you have to cut into the human body. Larry
Howard Norman
Gall bladder surgery has certainly changed in the last forty years! I had mine removed about 1970 or 71. Ten days in the hospital due to an infection, should have been seven days at that time. Supposed to have been at home for four weeks after that. After three weeks I went back to work because I was getting cabin fever. Best of luck in your recovery Jim!
howard
Excellent report, Rod
Thanks for the mini-tour of your new air system. It gives me some good ideas. Looks like a Shop Shot to me.
PS That shop looks too clean. Couldn't you clutter it up a little?
George Colonel's Workshop-Havertown PA
Good Afternoon Jim,
Hmmmmm! My doctor began chanting "Gonna get your belly button" over and over during a recent exam. I do the same chant to my little grandkids, who all have "innies". Pop-pop has a big "outie". I am deciding whether or not to do something about it. The Doc says its the least of my health worries. Hope you stop hurting quickly.
George
Speedy recovery, Jim!
Why is it PVC can't be used
bill tindall
I usually don't keep up with air discussions so I have missed the reason. But I got to thinking, a dangerous pass time, and thought how my 1" water line has experienced in excess of 400 psi (that is another story). So if 1" PVC can handle 400+ psi what is the problem plumbing 90 psi air in PVC.
I saw some neat flexible plastic air line demonstrated at IWF. I didn't price it.
Re: Excellent report, Rod
I'm sure you're aware of the techniques of perspective, framing, cropping, etc. If that's not plain enough, I'll grudgingly post a horrifyingly accurate rebuttal of the claim that it "looks too clean."
Rod
PVC can't be used
Wow, I thought that subject had long been settled. PVC doesn't react well to incidental impact while under pressure with a gas. There are published proscriptions against its use for such available on the web. As I recall, one is an OSHA document, and, for the government haters out there, one from a gas industry organization.
Apparently the effect of the above mentioned impact is for the PVC to shatter, sending shrapnel around. Not good stuff.
And the question isn't invalid—I don't think a single person has not raised the question upon reading the max PSI imprint on a piece of PVC. I know I did.
Rod
Azelea pen
Charles Yawn
Cut down a rather large azelea bush not long ago and was able to harvest a short piece of the trunk big enough to make this pen this weekend. Was disappointed in the wood as it is quite unremarkable in grain and color. About the only thing going for this pen now is that it is azelea; don't hear or see much about azelea wood.
Charles
Re: PVC can't be used
Thomas S Stockton
The other problem is that the oily gunk in the lines has a tendency to break down the type of plastic used in pvc pipe. I worked in a shop where a line that was a couple of years old let loose with out anything hitting it, boy did it make a huge racket so it does happen. I worked in another shop that had pvc airlines that lasted a long time and were never a problem.
I did what Rod did and used copper the last time I did my shop, it is actually pretty simple to use and sweating the pipes together is pretty easy.
Tom
thanks-curiosity satisfied.
bill tindall
I can see that there isn' t much energy stored in compressed water, compared to air, so pressurized water is not a hazard.
Moving water on the other hand.......for a while I was at the end of the public water line. A large tank was being filled upstream, resulting in a large mass of water traveling down the pipe. When the vlave shut off the momentum of this water continued to the end of the line. The resulting pressure surge blew out a 400 psi pressure regulator and bent the needle on a 250 psi gauge (actually knocked the needle off the shaft).
One more reason, maybe the most important
Gary Camp, Bend, Oregon
Stored energy, for all practical purposes water doesn't compress, so when a PVC water bursts little happens, except of course for a wet spot. Gases compress so one may have several times the original volume contained in the system. When a pipe containing a compressed gas bursts it does so with explosive force. A boiler that is rated for 50psi with water may only be rated at 10psi for steam.
Re: Azelea pen
Tony - Memphis
I have some pieces of yoshino cherry and wax myrtle that I have been allowing to dry for a couple of years. They are small, but I thought I may try and do somethig with them just because I planted them and grew them. The trees are alive and well, btw, just had to trim some large branches and had one storm damaged branch.
Tony
Harvest Time-Dell's Tree
Good Evening Charles,
The pen is remarkable and the wood is certainly showcased. I like to do things like that, and wish I was better on the lathe to make it happen. After we bought our home, the Japanese Maple tree on the front lawn became more diseased, and I had it taken down. I saved a section of trunk which was sound, and made a few bowls, which were very nice. I took one of the better examples and mailed it to the lady who sold us our home. Her deceased father had planted the tree, and I figured she would love to receive the unexpected bowl as a Christmas gift.
George
