4 Square without a table saw?
Stephen Kirk
I'm contemplating a new table saw, but I also need a band saw. Given that the world has gone table saw safety nuts I thought I'd take a bit and evaluate how I use a table saw. My main use is repetitive ripping, especially straightening stock after jointing. I follow the common practice of jointing one face, squaring an edge, planing the opposite face flat and then ripping the opposite edge straight and coplanar. My TS also comes in handy for miter cuts.
So, miter cuts are easy on my CMS, and since getting one I rarely change the miter gauge on my TS.
Now, bandsaws are great at ripping. But, can they also square and make two edges coplanar?
I've seen some articles that suggest not having a TS in a shop. If I was to go without a table saw, sticking with a bandsaw(have to purchase), jointer(8" Grizzly) and CMS(12" Craftsman), how could I do that final milling step? And do it without hand tools! Only other power tools.
My TS does tend to scare me (old Craftsman contractors saw). I'd love to put in a Saw Stop, but that safety comes at a steep premium (no, I'm not interested in a discussion about how much surgery costs). So, I thought I'd see if I can live in a table saw free world, as a few articles have suggested. I could certainly buy more bandsaw if I didn't replace the TS. Extra floor space would be nice, too.
Re: 4 Square without a table saw?
I don't see any reason you can't use the Band Saw to rip the other edge parallel to the first edge. I have a band saw and have a love/hate relationship with it. Actually, it's mostly on the hate side. I have a 14" Delta with a riser block. I keep adding upgrades and attachments. Recently added a Kreg fence and I think that would enable it to do exactly what you are talking about, but, I see some draw backs. With a good blade on my TS (a 40 year old Delta/Rockwell Contractors saw) I can rip some things good enough to glue up right off the saw. And the table is large. And on a different topic, I can cut slots and grooves and dados. The table on my band saw is about the size of a dime and you can't cut dados.
If I were buying another TS I would be seriously looking at the Sawstop. I have had a TS injury and the Sawstop would have been cheap.
If I were to buy another band saw I think I would look at one that is bigger and more powerful to start with. I have added enough doo-dads and upgrades to have bought a better/bigger saw. In truth, I think I need two band saws. A bigger one set up for resawing and other straight line work and perhaps the one I have set up to rough cut and do curves.
John McGaw
A perfectly-tuned bandsaw can certainly rip and make edges coplanar. The key there is "perfectly-tuned". Let anything at all go off a bit or a blade get a little duller on one side than on the other and all bets are off. One idea might be to use a planer to do the coplanar which is what I do when I have a mass of duplicate boards to turn out but I notice that you don't list a planer on your tool list (how do you survive without a planer?) Other tools which can bring boards to coplanar pretty quickly if they are "just a bit over" are a router table or a shaper with the former being far more common and cheap. If the output from a bandsaw rip is just a bit over-width and not-quite-straight then either of these or a planer can bring them right pretty quickly.
Stephen Kirk
Sorry, must have forgotten to mention the planer. I've got a Delta 12 1/2". You don't have any trouble with narrow boards being unstable standing on edge in a planer?
Stephen Kirk
I'm certainly thinking of a big bandsaw. Perhaps add a small one for curved cuts later on.
Fortunately, bandsaw makers are getting better, tables are bigger, dust collection is improved and extra support is easier to add.
John McGaw
No, I've never had a problem although that is why I most often use the planer for such work when I have a bunch to do at once -- stand them on edge, optionally clamped together (with obvious deference given to the blades) and they come out fine. I certainly have been known to run a single board that is all nice and true except for that last edge through the planer although if it was under 3/4" I might get a bit nervous about it.
The type of equipment may or may not have a bearing on the usage -- my planer is part of my big Robland combination machine and it has a metal feed roller rather than the rubber sort on portable machines. It would seem as if, if the table were long enough and completely level, a board should have no problem going through on edge without wobbling.
Stephen Kirk
I have my Delta on a rolling cart which I think I will add in and out feed support, since my garage is anything but level. That should help tremendously.
I'm limited to about 6 1/2" inches though, so I'll have to keep that in mind.
No table saw? No way!
Dick Coers
I can't imagine woodworking without a table saw. Yeah, a bandsaw can rip, but what if you missed the rip by a fraction? Ever try to take half a blade width off a piece of 8/4 white oak with a band saw? I'm not sure the blade will even start without deflecting a little, then maybe cut back in. I didn't read all the responses, but did cutting plywood come up? When I need absolute accuracy on a miter, I still go to the table saw. The blade is more rigid than any miter saw (again with taking off half a blade width. A miter saw will usually deflect as well with those shaving cuts on thick stock. Then how about surface finish? You will change blades a lot more often on a bandsaw, to even try to get something close to a table saw. I have never gotten close to the finish of a Woodworker II blade with my bandsaw. Put my vote up for a major table saw first as the first must buy for woodworking. But, maybe your work is different than mine. To each his own.
Second table saw over bandsaw
Dave Paine
For many years my main power tool was a Radial Arm Saw. Helped me build a lot of projects in the house. I then added a Sliding Compound Mitre Saw. Helped me to build my extension.
I later added both a Table Saw and Bandsaw. I would hate to only have one, but they have different strengths.
If I am attempting to rip 8 quarter maple, or a board which has a lot of internal stress resulting in pressure on the blade, I stop and use the Bandsaw, but I know the resulting cut needs to be cleaned up, typically on the Tablesaw.
As the previous poster stated, a Tablesaw and create a cut which requires zero finishing.
A Bandsaw at least for me, always requires re-finishing.
A good quality Tablesaw blade can give a smooth surface which requires no sanding. I have not seen any of my Bandsaw cuts which do not require cleaning up on the Tablesaw or a lot of sanding.
I do not let the SawStop debate prevent using my present Tablesaw. Like many other tools, it needs to be handled with due care.
Some months ago I saw one of my colleagues. His hand was bandaged. He had cut a tendon while dressing some pieces of chicken with a knife. Came close to cutting off a portion of the hand.
Should knives be banded because it is possible to cut off digits?
wouldn't be with out one
del schisler
i have 4 complete wood shop over the yrs. and i have never been with out a table saw. Also a jointer - band saw with riser - 5 router's and 4 router table's and sander's - leigh and name it i probly have one . I have most of all tool's . It is easer to just use the machine's that plug in. Of course all the hand planes ect. work. This is in a new age of getting it done. I know using a wood plane you get more out of wood working. But when you need to get-er - done . A plug in is the only way to go. my 2 cents
Wouldn't dare rid my shop of my TS..
Marv
If I did, I'd lose half of my assembly work space. I have extra big side extensions.
I do a lot of small work and my bandsaw gets turned on far more than my TS. When I want an accurate smooth cut, the TS gets the job. But if it's piled high with crap, I might compromise on quality and go for the bandsaw. It's sometimes a budgeting of my time that determines which saw gets it's buttons pushed.
Marv
Re: Second table saw over bandsaw
Larry in NW OHIO
Dave Where are all the lawyers suing the knife manufactuers for not making a knifestop so people don`t cut themselves. I always hear the lawyers say, "It`s not about the money" BS. If it`s not then way do they charge for their services. How many billions did they make off the ciggaretts, that wasn`t about the money I remember hearing. Rant off, sorry. Larry
You can take my table saw off of my...
cold, dead ....
Band saw blades "flutter". Sure, you can plane way the flutter. Don't get me wrong - I like band saws - I even have two of them. You just need a really large band saw with a really wide and thick blade that you can put a LOT of tension on to minimize the flutter. Or you can tune a smaller band saw - and still get flutter.
If you had a 24" 3 hp band saw with a 1.5" blade... Well heck - you might as well spend the money and buy the Sawstop. :b
Jesse Cloud
Can you get 4 square without a ts? Sure. Make that last rip 1/32 proud on the bandsaw and run it over the jointer for one pass.
I won't mention the brand name because this board is not friendly to the idea, but guided circular saws do very well on this, too - especially when the rough board is not straight or you want to cut at an angle to capture the grain.
I think about selling my TS from time to time, it takes a lot of space in the shop and isn't really earning its keep. But from time to time it is just the right tool (dozens of the same rip, jigs that ride the fence, etc.).
Lots of ways to skin a cat, easy to think the way you do it is the only rational way...
Jim Hoeller
The cost of a Saw Stop is a lot less than the cost of repairing two fingers chewed up on a table saw. Even when you add the cost of replacing the braking mechanism and the blade. I speak from first hand experience (no pun intended).
