Can I predict sagging of shelf?
ILYA Z
I want to build a roll-out shelf for some under-staircase crawl space. It's fairly wide, about 30", and about 50" deep. I have two questions:
1. If I know the size of the shelf, the type of wood I would use for it, and the amount of weight I expect to put on the shelf, can I calculate whether the shelf will sag and if so, how much?
2. What type of wood should I be using for the shelf? I expect it to hold things like paint cans and the like, so it should be able to hold a good amount of stuff with little or no sagging.
thanks.
