Switch/relay Question for DC
I have the Long Ranger remote switch for my DC. Its a relay that connects to low voltage switches on the blast gates. When you open the gates the low voltage closes the relay and turns on the DC. Bought it from WoodCroft. First one crapped out at about a year and a half and they replaced it under the two year warranty. The replacement lasted about two and a half years and crapped out. The local WoodCraft has stopped handling them but gave me the number for Penn State Industries. Penn State gave me the number for PSI Woodworking Industries. They said that since it was more than two years old I was on my own. Wanted the full $49.95 (retail) for a replacement. I was reluctant, so they said they might have a reconditioned one they would let me have for $29.95.
The label on the box said that if I open it, I voided the warranty. Since it was crapped out and out of warranty, I opened it anyway, hoping I could free up the contacts or advance the spark, or put the smoke back in or something. (It failed in the "on" position, so figured the contacts were welded.) No joy, the relay is sealed.
What I thought was interesting was that the relay says right on it "1 hp @ 110V" and "2 hp @ 220V". On the exterior of the box it says not to exceed 1 1/2hp. I'm running it on a 1 1/2 hp Delta unit which I also bought at Wood Craft. Could this be why they don't want you to open the box? The contractor is under rated, but they figure it will last two years in a hobby shop?
I know we live in a disposable age, but I expect products to last longer than the warranty period, a lot longer, not just barely make it.
Anybody got a better suggestion? I like the blast gate switches. Open the gate, turn on the machine, make the cuts, turn off the machine, close the gate. The DC is not in the shop, its outside in a little annex, so a Clicker would not work well and it would be something else to keep up with.
Does anybody make a 120 volt relay that will handle the DC for a long time? I could plug that into this and the DC into that, taking the high voltage strain off this.
