Edge jointing large boards for edge gluing
Terry Spawn
I am making a table top (42"x78")out of 1.25" thick quartersawn oak. I am making it out of 6 boards that are each approximately 7" wide. I started by edgejointing and gluing the boards in pairs. I now have 3 14" wide boards that have been planed and sanded perfectly flat. The problem I am having now is jointing the edges of these. I have a big jointer, but these are too wide and heavy to get a perfect edge on them. I still have very slight (probably about 1/32") gaps. Any Ideas on how to prepare these large boards for edge gluing? Thanks.
Re: Edge jointing large boards for edge gluing
Jointer plane
A sharp, well-tuned jointer plane will get those edges nigh-on perfect in no time flat. If you want, you can plane them in pairs, back-to-back, so that any slight out of squareness will cancel itself out.
Clint Searl
Clint Searl
Securely space the boards about 3/8" apart. Set up a fence on one side to center a 1/2" spiral router bit on the space. Route both edges simultaneously for a perfect joint. Setup is a bit fussy, but it works well.
Clint
John Veerkamp
You can use a table saw by hot gluing the pieces together and then hot glueing a piece of 1X over the joint. Adjust the saw blade to clear the pieces by about 1/4". rip down the middle of the joint. Perfect match.
FredD
Having a large jointer is all you need , but it needs to tuned.
All of the suggestions the posters have advanced will work , planing takes a certain amount of skill .
I would have no trouble jointing those glue ups on my jointer which is only a 8" machine.
If your jointer cuts a straight edge, the weight of those boards should actually help you keep them on the table , upright and full contact with the jointer table.
FredD
John McGaw
The sizes of the boards you quote should be well within the capacity of a "normal" jointer assuming it is set up properly and, if necessary, an assistant who understands the process is available. My experience with large boards gets to the realm of the ridiculous with 3+" thick, 6+' long, and 12" wide jointed on a 12" jointer but one with very short tables. The key is to maintain proper vertcial contact with the fence and balance across the tables. Let the board wander from the fence and you are screwed. Let the board get unbalanced forward or backward and you are slightly less screwed but the results will be bad. Having long tables and/or an assistant can take care of either of these problems.
David Hay Denver
Have you thought about using some kind of magnetic featherboards to help hold the stock up against the fence? This way you could focus most of your attention on keeping the board from tipping and feeding it through the machine.
David
Larry in NW OHIO
Terry I ave done this a few times with my router, similar to Clints idea. I take my router and a straight bit in it and set a straight board just a 1/32" more than the distance from the edge of the router to the router bit and fasten a straight edge along that line. You then route that edge and if your bit isn`t long enough then take a pattern bit or a flush trim bit and take the other side off. Simple as that. I hope you could understande my mummbleing, I`m note very good at explaining things. Good Luck whatever you do. Larry
mash them in the clamps
bill tindall
I figured that headline would cause some angst. It all comes down to how much tension there will be on the joint after gluing. A 1/32 gap, if it is not abrupt, will likely pull tight easily over a 6' length. If the gap is a step, it needs fixing before proceeding.
If you can pull the joint tight with modest clamp pressure, slather on the glue and do it. Alternatively, buy and learn to use a long hand plane to get the joint better. I have never been successful with this later route so I have learned to get it good enough on the jointer. Take light cuts. A taper cut often fixes gaps.
Clint Searl
But watch out for creep!
Clint Searl
del schisler
Why didn't you edge all the board's before any glue up's ? That would be all done. Just glue all boards than. But a little late now . Router table ?? You could use a streight bit. With a end feed table 1/16 off set to do this. May take 2 people to hold board's tho. good luck I didn't read any post's. so their may be other idea's
