Two more Bandsaw questions?
Has any one had bandsaw blades professionally resharpened? (I know how to do it myself, but have never found them to be quite as good as new.) Have the resharpened blades been good as new? What did you pay for the sharpening?
And, Anybody using one of the carbide tipped saw blades? I understand they cost about a hundred bucks. Are they worth it? I am afraid to buy one, because I have been known to trash a blade in a matter of minutes.
Re: Two more Bandsaw questions?
Good grief!!
bill tindall
A blade for your saw would be $10 at Misenheimers. Who could sharpen one for that price.
Re: Good grief!!
OK. So I'm cheap. I have about a dozen. If I could get them sharpened for three bucks, I could save $70. I could make a ham sandwich if I had some ham, if I had some bread.
If we had some  eggs, we could have
Bruce, a MN Galoot
bacon and eggs, if we had some bacon.
Bruce, a MN Galoot
I have a 1/2" Lenox Trimaster on my 14" Delta BS. It is a great blade, even after it took out a little trim nail. But that happened only once. I used it constantly for 3-4 years and still have it. It got swapped for a 1/4" when I needed to cut tighter bends than the 1/2" could make. The 14" Delta has just barely enough tension to run the Trimaster.
I have checked a number of sharpening services and even with Lenox customer service. They all say that blade can't be resharpened, that it is expendable.
Uses for old band saw blades...
1) Bow saw blades - if you haven't used one - try it, you'll like it. You can typically get 3-4 bow saw blades out of a band saw blade.
2) Shedding blade - for horses and dogs. Blunt the teeth with a file or stone. Cut into segments. Ideally you will have several "loops". I usually cut several (4-6) kerfs in the handle and put the ends of the loops in the handle. Put a pin through the handle and the blade ends. I also recommend putting a length of banding strap near the handle.
3) Tapering tool - make a cone on a lathe. Cut a thin kerf in the cone, about as deep as the band saw blade (just have the teeth showing). Have a straight section at the upper (wide) end of the cone. Drill a perpendicular hole through the straight section. Put a dowel through the hole. Put a band saw blade in the kerf. Voila - a tapering tool or reamer.
4) Rough and ready rasp - cut kerfs in a piece of hardwood (along its length). Put band saw sections in the kerfs - attach with epoxy or pin with nails, bolts or whatever. You'd be surprised how well they work.
Need any more ideas? Band saw blades are "disposable" - but they can still be useful.
Back Scratchers?
Re: If those eggs came from Iowa...
Al Stokka - Cambridge, Iowa
...you could have...
...wait for it....
Salmonella!
Groan.
Al
Not If You've Got Moles
Great on skin tags, though :D
Men of a certain age????
Never heard of skin tags until my last trip to the dermatologist. I thought it was a mole that had turned dark and was sure I was dying of skin cancer. Nope, a skin tag and meaningless. So, good news and a new piece of info. What the heck is a skin tag and are they contagious? Or is this something you get as you get older like hair growing in odd places. I know I need a hair cut when I can't hear anymore and have to get the barber to trim the hair out of my ears.
Re: Men of a certain age????
FredD
Some guys get them and some don't Barry , I raise a annual crop myself and the Dermatologist uses long dowel with a large cotton ball atached which he draws into a point and dips in Liquid Nitrogen and touches the Skin Tag.
It turns black in a day or two and eventually falls off though I speed that process up.
They are not contagious and some Docs have told me they are no more then a fatty tumor, but one in the wrong place can be aggravation ;-))
FredD
Funny thing
George Colonel's Workshop-Havertown PA
Good Afternoon Barry,
While I am a man, certain of his age, I've never heard of skin tag. Something Mark and I should mole over. 8)
George
Re: Funny thing
Larry in NW OHIO
Colonel I think they are, for the lack of a better discription, what looks like a very, very little mushroom growing out of your skin. About 1/16" tall, at least the ones my one SIL gets. At least that is what I remember she called them. If not I`m sure someone will correct me. Larry
