Wanted: Hardwood Dowel Pegs
Ben Allen
I'm looking for 3/16"x1" hardwood dowel pegs, specifically Ebony and Cherry, and other exotic hardwoods too. If you can make these please email me at benallen1980@gmail.com and we can discuss pricing.
Re: Wanted: Hardwood Dowel Pegs
How many? How accurate?
Re: How many? How accurate?
Ben Allen
Four of each. As far as accuracy... Within 1/64 would be nice. 1/32 would be tolerable.
For that many.....
you need someone with a dowel plate. I don't have one, but my understanding is that you cut a square stick and drive it trough a hole in the plate. I have never tried it, so I don't know how well they work. Not sure if you use a single hole or a series of holes. Also not sure whether the process produces beautiful "appearance grade" dowels or sort of utility plugs.
You could also turn them on a lathe. I could do that. I have the cherry and I may have some ebony. Does it have to be ebony (Really really black) or would some other dark wood like macassar ebony, king wood, or even walnut work? If no one else bites, let me know and I will make them on the lathe.
Wood Craft carries dowels, but I don't know if that includes 3/16" in cherry and ebony.
Re: For that many.....
Larry in NW OHIO
Ben Not to take work away from Barry, but I think, which is very dangerous, I have a catalog that deals in dowels, if you are interested. They may have what you want, If I can find it. Larry
Re: Wanted: Hardwood Dowel Pegs *LINK*
Jim Dillon
Ben,
For ordinary hardwood dowels (oak, walnut, cherry, mahogany maple), I've used Woodworkers Supply. But in glancing at their catalog, I see they do not carry 3/16 inch stuff except for one "tropical wood" alternative that likely wouldn't fit what you want.
Here is a link to Lie-Nielson's dowel plate that might be what you need - if you can swallow the cost.
Jim
Lie-Nielsen Dowel Plate
doug f, san clemente, ca
Ben - it's a stretch, but you might look at this tenon cutter. It may be long enough for you and you can use whatever wood you choose.
Doug
tenon cutter
Ben Allen
Thanks, Larry, but I'm really just looking for someone to use like a plug cutter or something. I guess I'll have to do it myself, but it's kind of a waste since I only need a few short pieces, and scraps of the woods I want are going to have to be ordered... plus I'll have to buy a bit that cuts 3/16" plugs.
Ben Allen
Thanks, Doug, but I'm just looking for someone to do it with their equipment. I'm not going to be using a tool enough to purchase one.
FredD
"but I think, which is very dangerous, "
I have occasionally felt the same way Larry ;-))
FredD
Yonak
Either Cincinnati Dowel or H.A. Stiles could supply 3/16" cherry dowels but, likely, not the ebony.
Get yourself a dowel cutter
Greenlee used to make (probably still does) dowel cutters that you can use to cut very ince dowels up to 2" long. I used to own several of them in different diameters, though not 3/16". Still, if they're available, it is the simplest and most effective way for small runs. Some of our mail order suppliers such as Lee-Valley, Woodcraft and Rockler may carry similar cutters.
To make 1" long dowels, start with a cutoff from your cherry or ebony board that is about 1 1/2" long. Plunge the dowel cutter into the endgrain as many times as you can to a depth of just over 1", then bandsaw 1/2" off the end to release the dowels.
