(Message Deleted by Poster)
Chuck Lenz
Chuck Lenz
That's a "misery whip"
...though, depending on the size of the tree you're felling, you might need one up to 10 feet long. Your collection is starting to look like some sort of creature on that wall, Chuck. I wonder what kind of saw the 27" blades were used on? Seems like the right size for a cutoff saw at a mill, or a firewood saw.
Re: Antique handsaws
I want one but I want it to actually use so I've passed up several that had chipped teeth or were way too rusty. Every now and then I get a log that my chainsaw just won't handle. It would be nice to be able to cut through the last few inches. When I first started turning I cut my found trees up to a manageable size with an ax. Then drug them out of the forest with a backpack harness and some rope. cut them up with a bow saw and fine tuned the shape with a side ax.
Chuck Lenz
Re: That's a "misery whip"
Bruce, a MN Galoot
There used to be a guy west of Mandan, who operated a sawmill. He cut up a couple walnut logs for me, about 15 years ago. That was the scariest operation I ever saw, a 4' blade completely unprotected with nothing except common sense to keep people away from it.
Maybe he'd know.
Besides, Chuck, you keep this up and you're going to be eligible for duty on the "quiet" side of the forum
One man saws
The tooth pattern of the one-man saw on the left looks to me like a timber pattern (can't recall the name; I know just enough on this subject to be dumb). The one on the right has been pretty thoroughly over-sharpened.
Googling "ice saw" brought me some images of old ones. The teeth were very large, and seemed to tend toward being symmetrical (one looked like it was filed rip - probably for the cuts parallel to shore). Your saw on the right looks to have kind of small teeth for ice cutting.
The newer ice saws listed on Amazon and so on seem to be for ice fishing, so I didn't look at those pics.
And I agree with Bruce Haugen: we're gonna have to get you over to the quiet side.
Marv
Nice restore job on that big O saw Chuck.
It's a bucking saw, used for crosscutting logs on the ground. A felling saw will be narrower in the middle. Almost the same width the full length of the saw.
I've restored a lot of regular handsaws, but never had the ambition to take on one of those big suckers. I can easily relate to the amount of time and effort you've put into it.
The other two smaller crosscut saws are also for sawing logs on the ground. An ice saw will have different type teeth that are similar in shape as a crosscut regular handsaw but much much bigger. They shaped the teeth with the same rake on both sides of the tooth, (30 degree angle) and the saw will cut in both push and pull directions. The teeth are referred to as a "peg tooth".
Marv
Chuck Lenz
Quiet side = *LINK*
Bruce, a MN Galoot
the hand tools side, Chuck. You'd be most welcome over there...
We call it the quiet side because we can do a lot of woodworking while the family and neighborhood sleeps.
The quiet side
The quiet side...
Marv
Chuck,
The Hand Tool forum is sometimes referred to as the "quite side" I think because they don't cover as many subjects as in here. I can tell you from experience that there have been times when a thread runs off the bottom of the page.
You aren't being too chatty, it's your kind of saw work that pops up quite often in there. There's a number of people in there who like to talk saws....I might be one of them.
Marv
Neither are ice saws
bill tindall
Ice saws have huge triangular teeth, they are longer and they usually have a second handle. I can remember when ice was cut from Lake Eaton in the Adirondaks, stored in an "ice house" buried under saw dust and dug out throughout the summer to be sold by the pound for ice chests.
The circular saws are for cutting firewood on a sliding or rocking table saw, or slabs or lumber to length at a saw mill on a swing-arm saw.
Finding is the easy part
bill tindall
These things require sophisticated tools and technique to properly sharpen. The operations are joint, file, set the cutters and swage the rakers. Each takes a specialized tool and precise technique They were called misery whips only when they weren't sharpened well. In my youth I had the opportunity to cut with these saws and it would be amazing to many how fast they move through wood. As much as anything they were replaced by chain saws because it didn't take the experience to sharpen a chain.
Good ones come up for sale around here frequently. Usually there is a person at Hillsville flea market in September that sells reconditioned saws. Also they can be bought new.
Chuck Lenz
don't know
bill tindall
Chuck Lenz
Marv
Chuck,
Yes, that would be a felling saw. Seems odd to be narrower in the middle than on the ends. Probably due to not maintaining the original crown or curviture. The reason for the smaller width compared to a bucking saw is to allow a wedge to be driven into the kerf sooner in certain situations and for the purpose for less drag on the saw when sawing. The main purpose is for less drag. Some of those old saws were 12 ft. long or longer. Imagine felling a Giant Redwood tree with one of those monsters.
You can probably get $20 for each of the other shorter saws. I see them on eBay all the time. The ones in excellent condition bring much more than that.
Bill says that some of the old ice saws had two handles. I'm picturing the guy on the other end....under water?
The buzz saws had large crosscut teeth much like a crosscut handsaw. They were shaped like "peg" teeth with lots of rake angle to make them less aggressive or grabby. You had to push the log into the saw with a little force to make it cut. In the early 40,s I remember my Dad using one of those things with a long belt driven by our big O Farmall tractor.
Marv
Chuck Lenz
When I get to Bis, I'll make the time and
Bruce, a MN Galoot
show you the basics of planing. The slope from then on is very slippery.
Schlep on over to Duane Voskuil's violin shop sometime and see what can be done with hand tools.
Chuck Lenz
Re: When I get to Bis, I'll make the time and
Bruce, a MN Galoot
He's a former philosophy prof from UND. I went there once in the early 90's and was pretty much blown away by the quality of his work and the fact that his process was almost exclusively hand tool oriented.
