Glue Age
Glue Age
Glue Age
I'm about to start the first flatwood piece that I've done in a few years, and realized that my gallon jug of TB-III [about half gone] is at least 5-6 years old. There's no born-on date on the jug, but it's old.
Anybody have experience with using this stuff that old? I'm thinking I might just have to spring for a new batch.
tia
Re: Glue Age
Re: Glue Age
Keith Newton----Little Rock, Arkansas
If the viscosity seems right, maybe,,,,,,,,,,,,,,,,,,,, but if it is thick, I would toss it.
What would you think it would be worth to insure against a bad case of heartache?
Re: Glue Age
Re: Glue Age
Doug Ridley
I say if it looks okay and smells okay try it on some scraps and if that works okay use it. I have never used yellow glue that old but have used the white glue that old with no problems.
Re: Glue Age
Only one way to know-test it
bill tindall
It is not possible to reliably predict the shelf live of anything because storage details are too variable. If it is too thick to spread well then it needs to go. In the case of regular Titebond that is the only performance test needed. In the case of the modified glues I don' t know enough about their chemistry to know how they may fail. In these cases, make a joint and test its strength.
Unless you have a compelling need for the modified glues, replace it with regular Titebond or similar material. They can last for years before loosing enough water to get too thick.
Re: Glue Age
Clint Searl
From the Franklin website
Clint Searl
"In reality, as long as products like Titebond Original, Titebond II and Titebond III remain fluid, without drastic change in appearance, they will continue to perform as intended."
Have fun.
Clint
Re: Glue Age
Condition
The stuff appears fine after being shaken (not stirred) a bit as it has always tended to congeal somewhat in the gallon jug.
Re: Glue Age
Re: Condition
Larry in NW OHIO
Mark I have some glue that must be 3+ years old and I`m still using it, and things have not fallen apart as of yet or split. But one thing I do over the years is to turn the glue bottle upside down every few months or when I think of it or look at it and think of it. I don`t know if that helps any but can`t hurt, but it still look as good as new. Larry
Re: Glue Age
Re: Glue Age
Hank Knight
Why risk it? Glue is cheap. I'd pitch the old stuff and but a new bottle - probably not a gallon.
Re: Glue Age
Re: Glue Age
Hey, it was on Special ;)
I also used it for glue-size on the edge grain of MDF, did very well at that.
Re: Glue Age
Re: Glue Age
Hank Knight
"I also used it for glue-size on the edge grain of MDF, did very well at that."
Good idea, Mark. I'll remember that. Thanks.
Re: Glue Age
Re: Glue-size
Cut it by 50% with water, apply with brush. Let dry and sand lightly, then reapply. When dry check to see if water beads or is absorbed. Beads mean you're good to go with topcoating after sanding the surface smooth to take out brush marks, otherwise a third coat may be needed. You can use any PVA glue for this, or you can buy actual glue-size from finishing suppliers. Wall paper paste works too. You can also tint the mix with dye to match the color of your topcoats so that rubs and dings (they WILL happen) don't show up nearly as much.
Re: Glue Age
Thanks. Good info.
Hank Knight
