Headboard Progress.....
I have been posting about building and bed for my son and DIL. Its a contemporary styled piece and the head board is 10' 8'' long by 42" wide. We have glued up the panels out of walnut harvested from the family farm. It's in three pieces, the actual headboard and a wind on each side for the nightstands. It's bolted together from the back and 7 bolts hold each wing on. I was thrilled when we bolted it up for the first time and it went together just as it should. The blocks showing through the face are spacers that are attached to vertical hanger pieces on the back, so that the blocks bolt to the base of the bed and the headboard hangs from the verticals to allow for expansion and contraction. At this stage, its stained, but has no other finish.
This thing is heavy and huge. My son keeps calling it the "Table". Looks like you could land an airplane on it. Wonder how much it weighs?
Re: Headboard Progress.....
"Wonder how much it weighs?"
Easy to tell: while holding it in your arms, step on the bathroom scale; check your weight. Now, set it down and step on the scale again; subtract the second weight from the first, and there you are!
If you really want to make it challenging, try holding it in one hand, while using the other to keep vertebrae from popping out of your spine and bouncing off the wall, possibly injuring someone.
Nice looking piece of woodworking. I do love walnut.
Larry in NW OHIO
Beautiful piece by itself, I just love walnut also an like to work with it. I wish I could find more things to make out of it. Get your scales out and put in the middle of the board and just lift one end on the scales and have someone look at the dial, if it hasn`t flew off somewhere. Larry
Re: 103 lbs., assuming 7/8" thick walnut
Al Stokka - Cambridge, Iowa
