Replacing Truck window Question
I went down to the farm today to bring some of my stash of walnut and cherry home. Got greedy and loaded one board too many and it slide in and touched the rear window of my pickup and broke it into about a thousand pieces. As I was considering the fact the fractured pattern looked good and I might just keep it, it started to fall out.
On the ride home I called around and the rear window is about $300 installed. That's $300 more than I have. I called one of those salvage it yourself junk yards and they have one I can come and remove form their truck for $30. I thought you could insert the glass into the existing rubber gasket, but apparently not. I am led to believe the glass comes with the gasket bonded onto it and you install the combination into the cab.
Incidentally, the dealer wanted about $500 for the glass, not installed. Wonder if that includes an new truck?
This is a 99 Mazda B3000 extended cab.
Anybody know how this works and if it is possible to remove the glass from the junk yard truck and put it in my truck without much in the way of skill or technical expertise?
Re: Replacing Truck window Question
Nat Robison
I'm not sure if trucks are set up the same a rear glass on a sedan but I just blew mine out dropping my golf bag on the rear glass of my 10-month old car.
The rear glass, like the windshield, is set in a bed of adhesive that needs to be done perfectly in order to keep out the weather. Also, I believe the glass plays a structural role in case of rollover.....another reason for competent installation.
I'm not shocked at the price you got. I filed a claim for mine and I believe the total cost to the insurance co. was about $300 or so less my deductible. If the rear glass is set in a gasket with no adhesive, have a crack (no pun intended) at it yourself.
Tom Dunlap
I've installed a couple of windshields in big truck and a sliding rear window in a pickup.
It was easy but the gasket on yours may be different.
One trick that I learned was to insert the glass in the gasket then lay in a strong string in the groove of the gasket. Set the glass in place. The string is then zippered to act like a shoe horn to roll the gasket into place. Before starting I bent a small flat screw driver into a 90 degree hook to use as a shoe horn.
I bet if you ask google you'll find step by step instructions.
Use LOTS of soap!
Jason Roehl in Lafayette, IN
Totally different process.
Truck rear windows are generally NOT set in adhesive. They are held in place entirely by the rubber gasket. You should be able to carefully pry out the glass on the junker by "unzipping" it (or "shoe-horning" it) with a thin, flat metal blade. Once you get a little of the inside lip of the rubber on the outside, it should go pretty quick.
Installation has a little trick to it. I've never done it myself, but I've heard the process from many different sources. You have to run a piece of rope all the way around the glass in between the two rubber lips. Then, you set the bottom in place and a helper (or you) on the inside pulls the rope to zip the inner rubber lip into place while the person on the outside applies gentle pressure to the window.
Now, I know all this is true for older, American trucks. Yours being a '99 Mazda could mean that I'm waaaaay off base. You'll know when you start to pry into the junker...
Jason
Re: Totally different process.
Virgil Johnson
I had a rear window installed in an S10 truck years ago and they used the method Jason described but they used a length of insulated stranded copper wire (around 14 awg) in the groove of the gasket. A slathering of WD40 help with the insertion. Still was a 2 person job.
comprehensive insurance glass breakage???
del schisler
steve mackay
I drove around with taped-up busted glass in the back for a couple years. It was one of those "It hasn't honked me off yet" things. Last winter I spent a couple hours shaping a piece of plexi glass I got free for nuth'n. Another half hour carefully fitting it into the molding. Got a nice tight fit and it hasn't scratched up yet. I HAVE banged it hard enough that, had I put glass in, it would have busted. So I figure that, for THIS accident prone child, the plexi was an up-grade !
You could try an aftermarket sliding one.
Mark Nowicki
myspace.com/autoglassamerica
Mark
John E in SC
Back YEARS ago I remember helping my Dad replace the back window on our old Ford pickup with one with sliding glass. I can't remember much about the details, other than that it was much simpler than I thought it would be, and only took a few minutes. No adhesive was involved. Give it a shot - I'll bet you find it well worth the time to save $270!
Larry in NW OHIO
Barry I had an 1985 S-10 best truck I ever had, well anyway I broke the bach window. What I did was go to a repair place and ask if they had a window for it and had to believe they did, paid $20 for it and he even showed me how to put it in, took all of a minute. If your truck is anything like that was you should not have any trouble. Since your window is already broke, half of your work should already be done. The gasket is in the opening so you should see how it comes out. if you go to that like Mark gave you you should get some pointers there. If I lived close to you I`d be glad to help you.Best of luck to you. Larry
