Re: bandsaw thumping -solved??
paul in AZ
I may or may not have solved at least part of it.
I carefully checked out the weld which looks OK to me [like I REALLY know]; the back edge is plumb; and tooth gap is good. So, I spun the top wheel manually under minimal tension and watched the blade. There seemed to be an intermittent wobble unrelated to the weld. When gently touching the blade while spinning by hand I could feel a single area that felt 'lumpy' for lack of a better word. This area looks like it had been deformed or bent. I could easily have twisted the blade in some abnormal way when uncoiling it, putting a bend into the metal. I'm guessing here.
Next i put a little extra tension on it and started to open an olive crotch I've had for several years to put tension and some heat on the blade. After a bunch of slices the thump lessened and has almost gone away. Back to spinning by hand and it feels like that ?twisted lumpy area has pulled out nearly flat.
Was that really the entire answer? Who knows?
The blade seems to cut well and I'll not worry about a breaking weld.
The real disappointment is now that this olive crotch had all kinds of twisting internal splitting and is mostly unusable. Win some, lose some. The crotch was free anyway so all I lost was the years of storage.
Thanks for the responses guys.
